Not bad for 18psi any dyno graphs ?
When is it on full boost by
does it drive good and feel responsive on road or the car ain't registered?
On a cooler day should pick up another 10kw at least without even touching the tune
my mates built sr20 corolla was tuned last Thursday in 40degree heat made 330rwkw then went back on sat same dyno same tune made 357rwkw
Eh. I've seen cars do straight back to back runs in dyno competitions with more than 50 hp difference between them. Loads of variables.
The important thing is how the car drives, and by the sounds of it Scott is pretty happy with that, so I'd say it's a good result :) Also keen to see a graph though Scott! Any plans to switch to ethanol or WMI?
Thanks for the feedback guys, its just my luck to have it tuned on the hottest day recorded since 1930 lol
I got to have a little play once I got it back to the area and I can say it is fast. Its got a solid powerband from 4000-7000, a good 3k of fat power. I do think I might want to get it touched up on a cooler day though, there are a couple of areas that I feel could be improved.
Having let a friend drive the car first was a mistake lol, the stock 3.7 diff ratio can really make the car feel dead if your expecting it to boost from 1700. Once I jumped in for a hoot having a reasonable idea of keeping the thing on the boil made it a completely different animal all together.
Unigroup said the car gave them zero hassle, went on the dyno and tuned right up. They were very impressed with the way the setup behaved and said the motor itself was possibly the best built motor they have had come through there in a long while.
Ill attach the graph here for all to see.
Also got my car back from tuning by C-Red today. I was a little sad panda when Mark said It made 335rwhp on 16psi (they say they have a low reading dyno). However it pulls hard once again, like it did with 375rwhp on 21psi last year, so im wrapped.
It didnt seem to like 20psi very much with lots of pinging, so timing had to be taken out a fair bit.
Taking it to the drags on wednesday to see what's what. ;)
Going to try and improve on my results and sort out my issues once I get back into work. It's been ages and I'm still happy with how it drives but I feel something is holding my SS1PU back with it making 250rwkw @20psi
The WMI will help with the heat issue but before doing that I was going to check my whole exhaust and actually see what size it is throughout. Making sure the exhaust isn't the issue then I guess I'll have to move onto my intercooler.
Anyone heard of a 'Hybrid intercooler'? I must be lucky because it also says its limited edition haha
Most probably something cheap and this could be why I need 20psi to produce the same power as people running 16psi such as birds results.
Stao has given me some good advice to check the boost reading before and after the intercooler to see if it is losing pressure or anything. I haven't had the time or money to go source new intercooler pipes to chuck a nipple on and a boost gauge yet.
Time will tell :)
The graph looks similar to the turbo I got now on pump 98 td05h18g kando
http://nissansilvia.com/forums/index.php?showtopic=498401&st=90
If Hypergear could make something similar to the hksgt2530 I had I would get it fullboost by 3500rpm 20psi 180rwkw by 4000rpm on sr20 thats the most responsove setup ive had so far and ot drove the best And still made decent power on 21 dropping to 19psi 251rwkw e85 drives better than the setup i got now td05h18g e85 24 dropping to 21psi making 264rwkw
link to dyno graphs and comparisons are in the link above the power curves abit wobbly cause my boost solenoid was cactus
I think I might give his new billet ss1.5 ago seems like it should make similar power as the hks gt2530 and response his sspu is similar to the td05h18g I have now full boost 4000rpm 20psi and made similar power
Edited by hy_rpm
Just make a manometer :) Will cost maybe $10 to make and will be far more accurate than any boost gauge you buy.
Will remember to avoid C-red then :whistling:
WMI :) do eeet!!!
http://nissansilvia....ic=498401&st=90
Shouldn't be an issue matching the 2530, The new billet SS1 might perform better within the same HP range.
The SS1PU is a larger turbo compare to T518Z, Per Abe's result its already sitting 265rwkws on Pump 98.
E85 results with 98 is not directly comparable, there is a 40kws difference in peek power as well as mid range.
If the SS1PU's peeking 248rwkws @ 18psi on pump 98 on at 45 degrees day. On E85 it should be pushing towards the 280rwkws mark with slightly better response. I'll be looking forward to the final E85 or P98 tune once his engine runs in.
Also response is pretty decent for a none VCT SR20det too.
I got a hybrid inter cooler kit fitted 10yrs ago for $1400
Have never tested drop across it
Haha shit $1400
So in this day and age would they be significantly cheaper?
Once I get some pipes I'll check.
Should it be 0 boost drop or do most have at least a little?
Haha shit $1400
Mine had 1psi on full load in 4th. Which in the scheme of things is fark all. Ideally you want 0, but 1-2psi is good too. It's when you're getting 5/6/7psi that you have an issue.
I'll send that PM soon dude, just sorting out the mrs ;)
Nah I have a pump 98 result in the link aswell
It's making 231rwkw on 19psi by 4200rpm on 20psi made 237rwkw
His one is 234-5rwkw on 19-20psi by 4000rpm if you read his graph
mines non VCt aswell same dyno same ramp rate same tuner
On a hot day it will boost up faster when it heat soaks but not make as much top end power as mine did that when the radiator was no good coolant temp was getting to 100•c on the dyno but I couldn't believe it full boost was 3600rpm once we let it cool down for 15mins power was back up 10kw and boost back at 4000rpm
If you overlay my td05h pump 98 dyno graph over his ss1pu one it's very similar
Abe's result you can't directly compare cause its a different dyno different tuner larger cams 272 duration 12mm lift and it 263rwkw at 19psi by 4250rpm
Mine and scotts results same tuner same dyno same cams poncams same boost
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
