Thanks for the input Disco, that would share us with more light into the turbo systems of the EVO series.
When making a customized compressor wheel, the size of the actual wheel no longer represent the approximate power output, how ever depending on blade and hub profiles, plus individual preferences.
In comparison. I'm pretty certain that the the standard 74mm SS2BB with .82 turbine is a very close match in terms of power and response to the HTA3076. And VNT result of that is in page 395.
SS3 is closer to a 3582 equivalent, and pretty laggy in standard .82 turbine housing. I've only built 3 of those in the past and one of them was a high flow that made 344rwkws on E85 Auto, internally gated, stock manifold as a factory replacement.
Stao did you end up working the SS1PU VNT turbine housing? I've already got one of those installed how much is for that housing by it self? Very interested in the comparison.
I'm pretty keen to see how a SS1PU VNT is going to shape up.
Engine wise the Evo 7 (GSR) was a carry over from the Evo 6 but they changed (I think) to hollow camshafts and added EGR .
Turbo wise the larger heavier Cedia based E7 went back from the Evo 6s 10.5 cm turbine housing to a similar 9.8cm sized one with the cold side unchanged . The std torque peak moved up noticably 500 odd revs from Evo 6 to 7 and I think they went looking for earlier turbo response to try and get some mid range squirt back . Also they would have been struggling with emissions in that 2001 era hence EGR etc .
The 8MR and 9s also use the 10.5cm turbine housing but its not the same as the E6 10.5 , instead of two holes and two wastegate flat valves the later one has double "D" shaped outlets mirror imaged to form a circle and uses one large waste gate disc/flat valve . Many people consider them to be better than the E6 one and you'd think Mitsy changed them to get better results . The thing is Mitsy kept increasing std boost levels right through the Evo Lancer models up to I think 21 psi with the 10s . People say the early 10.5s can crack over time and replacing them fixes some boost issues caused by the leaking gates .
Mark at GT Pumps used to sell an aftermarket 10.8cm direct replacement turbine housing which people like . I've been in a 7 with one of these on a std turbo with the IC pipe changed plus the exhaust after cast dump and E70 , its a bit of a weapon for a roadie and drives nicely as you'd expect with std valves cams etc .
A .
I dropped the Evo 7 stock turbo off to Stao tonight, we compared the housings to another customer's and could barely see a difference, although my 7 turbo had a 10.5 rear, and the evo 10 turbo had a .98 rear. Should be interesting to see what a completely stock looking setup can achieve. (still need to register the car) For now I plan to run the backwards billet ss2 in stock housings with the Manley 2.3 stroker kit on stock cams and exhaust, with the possibility of e85 in the tank.
Ive got a mate scotty who has an evo 7 or 8 im not sure on that bit, he is using his stock turbine housing with a upgraded billet front 25g wheel and anti surged cover, on 33psi e85 and running around 330awkw, very quick setup, he is now building motor to 2.3ltr for 360awkw in stock housing, upgrading the turbine wheel this time.
Edited by methz
IIRC the evo x housing is 12cm, which you wouldn't see the difference on the outside.
Also a 10.5cm is probably .7-8 AR with the TD05H inside. So .98 for stock evo x is probably right.
This could be lengthy and not Nissan related . Scotty absolutely your call but I'd be researching MiVec 4G63 heads first because having variable timing on the inlet cam is supposed to make a considerable difference to the low end torque . Don't quote me but I think I remember reading that Evo 9 exhaust cams are the warmest of the std cams and the low end with a Mivec head is noticably stronger even with hotter cams .<br />Now I'm not 100% sure but I did read that Mivec was not just a VCT change and head cooling was improved behind the exhaust side of the chambers and exhaust ports . They use a smaller diameter long reach spark plug similer to bike engines and it's all to do with improved cooling and detonation resistance . I can't remember for sure but 9s may have run 17+ pounds of boost standard and with even good pump fuel they obviously found problems because its unusual for a manufacturer to spend money on an enging towards the end of its life . Emissions may have forced their hand a bit here .<br /><br />There is lots of info out there on stroking 4G63s but the thing I noticed was that the Japanese kits never went as far as the American or locally sold ones . Off the top of my head a 4G63 has an 88mm stroke and 85mm bore but the rods are a reasonable length . Mitsy made larger capacity 4G family engines like (numbers from memory)4G64 and 4G69 . The 64 uses a taller block and a bigger bore with a 100mm stroke crank . I think the 69 uses the same block height with a 100mm stroke crank and shorter rods . From memory the 69 is a Mivec engine cooling wise . The Americans are all over 100mm strokers and often use the taller 4G64 block to get a bit better rod/stroke ratio - its all there on Evom.net .<br />The Japanese do I think 94mm stroke kits and these may work a bit better in a 4G63 height block . Mark at GT Pumps has a 2.3 stroker 63 in his car and he did tell me that they can have bore ring issues if you flog the tits off them rev wise - too much thrust on the bores with 100mm stroke and shorter rods I suppose .<br />A feller at work has a different Evo 7 GSR with a Jap stroker kit and its an animal he reckons if he boots it around .<br />I believe it has a mild high flow but not to sure whats in it .<br />PLEASE don't try using same compressor family 18 and 20G wheels with the std TH05HR turbine , very easy conversion vith really laggy results . The jury is still out on the HKS BB 4G63 Evo turbo , early ones had I think wastegate arm problems something like Garretts GT3076R Evo 10 turbos did .<br />Also , best to start out with an Evo 9 style center section because the cold end "flange" is larger in diameter than the earlier 4-8 twin scroll reverse rotation turbos . The 9 turbos use a larger diameter diffuser section and the larger 9 style compressor housing won't go on the 4-8 turbos smaller "flange" so to speak .<br />Because the compressor housing is different the tube on the outlet is different I think to miss something on the front face of the engine . Aftermarket ones are said to flow a lot better than the OE 9s steel one and I think Mark sells the good ones . There may also be a minor difference in the oil drain tube and I believe the early one can work but to be 100% sure a 9 ones probably best . LOL I also read that you bolt it to the turbo before you mount it - saves some agro it seems .<br /><br />Lastly my tuner reckons that many of these "coloured" Evo turbo upgrades still lose torque down low an I reckon the more material you bore out of an OE turbine housing the less efficient the turbine/housing combination becomes .<br />Geoff Denmead sold me my E6 and I reckon he knows a bit about them because ha won his class at Pikes Peak a couple of years back . He continues to beat on the dirt and hill climbs other Evos with "cheater" or std "looking" turbos mainly because they loose the lower mid range you need in competition . He uses a bluprinted Evo 8 turbo I think with a 10.5cm turbine housing .<br />I think people confuse minimul lag with close short gearing in an Evo Lancer because that makes it easy to get away with engines lacking torque down low - and its this low to mid range torque in an engine that still revs freely to 7 that makes an Evo feel fast . With good tyres they explode out of the blocks provided the clutch is good because they can put all their power to the ground - all that low to mid range torque with solid all paw traction . When they lose this torque they feel a bit flat unless doing big rev launches and thats not going to be good for the driveline .<br /><br />I'll wind up with gearing . My 6GSR has close ratios 1-2-3 with larger gaps 3-4-5 which is fine on the road because the short one get you going . If you want performance over highway cruising the RS ratios are close 3-4-5 as well and the 6RSs had an optional 4.8 something diff ratios , I think GSRs are roughly 4.5 .<br />The RS gearing is supposed to be very quick driven flat out through the gears and they can take them all to the redline . The Evos had all this available through the Ralliart factory arm because they , the 4/5/6 RSs anyway , were Grp A homologation specials .<br /><br />Sorry one more , diffs . It your cars cained often think about losing the AYC rear one for the RS mechanical one because its lighter stronger and more predictable . ACD can be good and there are now people here who can flash it's computer rather than being raped by Ralliart for their black box .<br /><br />Having said all this I still miss driving my Skyline if its away being worked on and I have to resort to the white rat .<br /><br />Such is life cheers A .<br /><br />BTW I think the Evo 10s turbine housing is 12cm but that ones a clockwise rotation turbo .
http://forums.evolutionm.net/evo-x-engine-turbo-drivetrain/414293-size-evo-x-turbo.html
Edited by discopotato03
Seems the turbo Stao built isn't off a 10 then, it was reverse rotation.
I would have loved a 4g64 block but I was worried the engine number change would make it harder to register, and I prefer to leave the original motor in there for some chance of looking stock. I won't be revving the crap out of it, 8k hard cut should be fine. I am expecting the highflow to be on boost by 3.5-4k with the non Mivec head. I will have to look into the 7rs diff as I have heard the AYC will crap out.
Whilst I would love a Mivec head, I just got the call my 7 head is rebuilt. Gotta go. :)
Ya, me too, got my ss1pu back in November and this new VNT housing sounds like it'll make quite a difference on the bottom end response on SR20.
The turbocharger is complete. I'm waiting for Trent to come back from the UK to tune it. I've also made an even more advanced VNT system, it should be able to knock lag out even further, Looking to trail it on the SS4CBB turbocharger. Hopping to archive 20psi before 4000RPMs and 450rwkws+.
This sounds mental. Cannot wait to see these results stao. When the price comes down to about $1700 I'll be buying one of these VNT bb turbos. :) can't wait. :)
Let me see how the SS1PU goes first. I think for some thing that is already that super responsive, by making it even more responsive might rise surge issues.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
