That one is a bitch to change
Good luck
Thanks prob get some mates over so I don't have to do it all alone and to talk shit
Sorry to hear mate, Buy some gaskets and change anything suspect while your on the job :)
This will be the go if I'm changing that may as well fix the lot
G2.5 is a smaller turbo then a G3, they generally maxing out towards 260rwkws mark. So its about at its limit.
He's right, the graph shown is for a G3, but the intake leak might still be present and causing the 5ish psi boost drop. Fixing it might get him another 10-15kw from threshold to redline, definitely worth investigating.
http://www.hypergearturbos.com/atr43.html
The link says G3 but that is the graph from the G2.5 on the page. Either way I will suss out any leaks and give it another run soon.
That G2.5, I thought was a high flow. Preload the actuator about 10mms, if it starts to pin then its usually a restriction some where. This one don't have much of boost drop.
also stao,
your new website isn't meta tag searchable/ google submitted as i cant seem to find the new one on google which is meant to have more details on your range then the old website
Hiflow of a stock 25 turbo? It has a 3 inch inlet so i don't think so
lol... does it fry tyres when you smash the pedal?
Yes it does, because the car is so big and front wheel drive, it wheel spins on the spot with stock tires. lol
Preload the actuator to about 10mms. If you a have a boost gauge, check the pressure drop before and after the cooler, also try a run with no exhaust on.
Time for some M/T tyres? :P lol
This is for a good comparison of the new ATR28SS1 V ATR28G1 based on the Kia's G4GC engine:
SS1 at 8psi, G1 at 12psi:
ower:
Thin red: SS1 @ 8psi,
Green: G1 @ 12psi
Thick Red: NA none turbo @ 0psi
Boost:
Green is G1,
Yellow is SS1
SS1 at 14psi, G1 at 12psi:
ellow: SS1 @ 14psi
Green: G1 @ 12psi
Red: NA @ 0psi
Boost:
Yellow: SS1
Green: G1
This is an excellent turbo for around the 200rwkws on a SR20det.
I don't think that would be a problem. I can upgrade it to the latest profile, which is targeted at boost dropping issue with internal gate. PM if interested to go ahead.
Those are a set of CT20 Toyota Supra turbochargers that I've recently done. Those are rated to about 400HP each. Running ATR28G3 CHRAs. photos shown compressor and turbine wheel comparison, profiled compressor and turbine housings, and completed turbocharger assembly.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
