Dummy fit to engine today and made dump pipe. Bit tight but fits nice.
Getting exciting now. Engine can come out tomorrow and then can get ready for the new one to go in :)
Posted Image
its 850cc with a fuel reg. the afr stayed at 11.5 till 5500rpms and rose to 13.2 by 7000RPMs. Which is maxed out.
Now lets talk a little bit with that 345rwkws E60 result on a AUTO. Auto usually fall 15% behind a manual which means that is equivalent to 390rwkws manual power.
Not only that, this power is generated from stock exhaust manifold with internal gate as a bolton high flow, I'm totally amazed it got there. So translate that into manual power then add additional 50ccs out of each injector, that flow rate is pretty close to getting my current result.
If you find that high flow is too big, then I'm more then happy to have it modified to a smaller version for better response.
Trent is extremely cautions with my car because its done couple of hundred dyno runs, and we occasionally take it to do quarters. its all been very safe or no differ then what he would normally do to a customer's car.
WOW ok while it still is a crapload of power for 850s that makes it seem a bit more understandable that it managed to make it - most wouldn't push that hard but regardless that more or less confirms it was moving the air needed to make that power and really the injectors were just no way near up to the task. 1200cc even seem like they're pushing it if you're aiming for over 500kw!
Yeah no question that the auto result was high IDC for the power, and the reasons are reasonably clear. All makes sense now :)
Add in two more results from recently customers.
This one is from iruvyouskyrine, Which is a Rb25det motor inside a R32 shell. Runing a ATR43SS2 bolton version internally gated with usual mods. Car made 312rwkws @ 19psi on Pump 98 fuel.
And this is from another customer has a R33 skyline, usual mods, ATR43SS2 bolton version internally gated turbocharger on E85. Car made 321rwkws on 20psi.
Posted Image
Posted Image
Worth noting that mine is a NEO stao. Also I am impressed with the amount of effort stao put into my car when he found that it wasn't running correctly. Not only does he make a good product but he has excellent customer service and satisfaction, which is a huge addition to the business IMO. Thanks stao and I am stoked with my result to say the least!
Nice results josh.. Now all we need is to see phatlavish's results when he gets his ss1pu installed for a direct comparison of the latest ss1pu vs the latest ss2 :D
Minor update. Dyno reading of another SS2 turbocharger sent in by a customer on a R33 skyline.
307rwkws, 98 fuel, actuator pressure.
By the way I'm planing to re-launch our website with a modern touch. Is any one here recommended for website designing and coding?
Just use WordPress mate, easiest way to knock up a website. Should be able to get a site up overnight and go to themeforest.net and purchase a theme you like... piece of pi5s
Stao visit, www.asapwebsites.com.au its a mate of mine who runs it. We came in on Saturday for a temporary chra. And give him a call. He should look after you
Hey Stao, in regards to the r33 ss2.5 high flow, would this intake pipe be good enough to run 300 - 340 rwkws.
They are sold be performancewise on here, or if anyone has experience with them?
CAPP53- ALLOY INTAKE PIPE - R33 GTST STAGEA
SS2.5 in stock R33 housings It won't make 300~340rwkws on a Rb30det. Probably a super responsive 250rwkws, rear end is too small for that engine.
Induction pipe needs to be at least 3 inches.
Hey Stao, i would suggest Nitro IT for having a website built for your business, i had one made for my BJJ club and it was an excellent site and was very cost effective, plus the the web designers are skyline drivers and members of skylines australia, look em up http://nitro-it.com.au
this are the OOOOO motorsports 1200 cc injectors arriving for tuning tomorrow. Hopefully they idle smoothly and sitting the car closer to the 500rwkws mark.
Thanks for every one whom recommended web designers. I've spoken to asapwebsites since he's local, new site should be up and running very soon.
  • Like 1
Stao make sure you post up results about the injectors too :)
I believe they are a great injector and someone just needs to give the right feedback to prove it.
Interested to see how those injectors go. Might be a good replacement if I go E85 and the 740's dont hold up. At the moment its anyones guess what it will make on pump fuel let alone E85 so will cross that bridge when I come to it anyway
I also just got these today in the 1000cc will update as to how they go as for 600 great vaule.
Tune was cancelled today, I guess Trent had some thing unexpected happening. now rescheduled for next week.
Also we are a little over stocked with our billet SS2.5's parts. Now offering cheap for $850 each complete turbocharger with oil line. Those are capable of doing about the 270rwkws on pump with excellent response. Details of this turbocharger's performance externally gated on E85 is at:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-364
This will be a complete turbocharger. with a .60 comp and .58 turbine with a Nissan 6 bolt IWG assembly. It is a brand new turbocharger, Not a high flow service
  • Like 1
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
