+1 for the above - He really will.
Is that new thing suitable for, I dunno, some guy wanting to run a low mount smallish turbo at 28psi on a RB28 auto sedan? ;)
LOL you sir would likely be happier with a straight SS2.
However, the new highflow profile amazes me, and a PU version of that (.82 T3 rear housing) might just rock socks on your motor!
Got some feedbacks from the ATR43SS4 built as a Ford XR6 BA internally gated bolton turbocharger. Its doing 408rwkws on 18psi P98. I think the turbine end is maxing out, it really needs a large external gate for more power.
LOL knowing the Ford Barra thats probably revving to 6,000... Meaning its on full boost preeeeeetty close to 3,000.
Thought I might just let everyone know.. LOL
Just a heads up to anyone who wants to go bigger then SS2 and go low mount, think again :P
my SS2 JUST fits, But it does fit, Engine is in the car now, cant wait to see how it goes
It's not far off from what I can tell. We did some trial fitting and working out exhaust/wastegate configuration on the old engine.
Its probably slightly different but not a whole lot off. But I'd say the stock side mount manifold wouldnt be quite as tight
I cant remember what Stao's Brae manifold is off the top of my head?
Nice. Does that manifold mount turbo in exactly stock location?
It's pretty much the same deal with the stock manifold, my SS2 fits but only just (on an R34). The actuator to chassis clearance is 1 or 2 mm so it's tight. Also due to the overall length of the turbo the intake and OEM intercooler piping will need some customisation. For a direct bolt-on a highflow is the easier option.
Wow! Looks pretty cool, but pretty intense - I always kindof liked the idea of a low mount setup but after seeing a couple I'd say it'd be a pain if you had to change turbos haha. Out of interest, depending on what brand you go you can get a MASSIVE amount of power out of that size frame - even the 900hp FP3794HTA turbo uses the same housings as you have there, so I am sure inside and outside of the HG range there is plenty to move up to if you end up needing more power than the SS2 can give you.
Be good to see results :)
Im trying to keep it as legal and non sus as possible while still chasing decent power.
I know the 6boost hardly looks stock but at least theres not a turbo hanging up top lol. Power steering line is fouling on the joiner off the comp housing. Can kinda see it in the first photo. Thats about the only issue
Stao..how about you make one with a Gt37 style turbine. like i said in my messages
a while back ...the rb30 boys would be able to use that aswell...Ill even test it on a mid 10 sec car..lol
cheers
darren
Haha, i missed the end.
ATR43G2.5
Keen to see how it goes I have g2.5 and currently underwhelmed with my result and unsure if it's turbo or something else that is lacking.
What was your result and why are you underwhelmed?
250rwkw. Hits hard about 3500/4000 which is good but after that the power just flattens out has no extra go at all pretty much gets the 250kw at 4500 and doesn't climb from there
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
