Yes, we did get the Adaptronic tuned running. The internally gated VNT turbocharger didn't work according to plan, but I did get plenty of data for further research work.
Regardless, VNT internally gated system is proven working, and have made a difference in turbocharger's response:
If I have time finishing off the newer prototype, it will be trailed again on the 29th.
Finally got my car tuned. The thing pulls damn hard. Will get a dyno run in the next few weeks to see what its making, there may be a very slight exhaust restriction that is affecting (very slightly) the boost right up top, but feels pretty damn good anyway :D
It feels rediculous to me, easily spins the 265s on the rear in 2nd and can keep it going through 3rd. My tuner said he had a hard time smooting the boost because it was so aggressive lol....
love it so far. Going to see if i can get it on a dyno before I go back to work wednesday but may not happen between now and then
Reminds me of how I feel about my SS1PU :)
Honestly the dyno lies to me, comparing my cars to similar examples with non HG turbos just feels unfair. Mine is so raw and aggressive.
Hey Stao
If i send you my stock manifold and my ATR43G2.5 could you do you custom external gate mod and make the rear housing external gate.?
( and update turbo revision if any better than mine ~ 1.5 years old )
I can upgrade it to the current SS2 for $250 if you prefer, and ask M35scotty to do the external gated rear housing mod.
How ever I have picked up a lot more power from externally gating through factory exhaust manifold, it is preferred if you can do the same. See if Scotty can do that for you.
If the ss2 is better sure,
As for externally gating, that would be the new gate off the manifold you tested start of January yes?
Would you need to put a different rear housing on the turbo? Or do u just weld internal shut?
Also, i cant seem to find Scotty's details... i must be blind :S
Is he over east?
Is he over east?
Isn't everyone over east? :P
Stao only uses one casting of .82 internal gate housing for skylines as far as I know, I have asked him for an external housing a few times but it would obviously blow the cost out, as he is tooled up to cnc the internal. I can weld a gate to the housing easily as I have a jig and know where the gate will clear. You would need to organise your own screamer/plumb back pipe locally.
I have to jig up a stock manifold for a suitable gate position still, so I can't really make one until I have an rb25 on the hoist, and a spare manifold. I was hoping to get over to Stao's to check his out, but he is the other side of the city, and we are both too busy atm. Hopefully I could sell it as a kit eventually with the gate and screamer pipe, but is there much of a demand for this setup? I would need to set up a cash back on return system for the old stock manifolds.
Welding off the housing would be best for shipping purposes obviously, and there are so many cheap options out there for housings now, like the stainless Vband Tial copies I use on my car, which make turbo/exhaust swaps so easy compared to the 6 bolt Nissan.
I has a few spare rb25 stock manifolds :D
Hi
Since the turbo is being rebuilt , is it okay to get a blown turbo and send it to you to be rebuilt with the standard highflow service for $800 + gst?
Cant leave my car of the road to remove turbo so thought this would be the best option
So I upgraded to the SS2 after blowing my tr43i and got it tuned today here are the results. Made 343kw on 18psi on a very conservative tune it has much more in it if I wanted to but my aim was 350kw as more power is useless to me on my drift setup.
Comparing it to my old turbo the tr43i that made 340kw on 21psi with the same response but with more timing along with 3psi more and the turbo was really being pushed to its limit especially with the 0.63 rear. Overall very happy with the result as expected the turbo performed excellent. Also btw my setup consists of all the usual bolt ons, brae top mount mani and hypergear 50mm gate for ppl that dont know.
post-50426-0-79844200-1390380431_thumb.jpgpost-50426-0-24964200-1390380494_thumb.jpgpost-50426-0-59164700-1390380554_thumb.jpg
  • Like 1
Hi
From the website:
Condition of the donor turbo. Donor turbo can be blown, with broken fins, or damaged wheels. Cracked housings depending on the extend of damage has to be repaired prior profiling. Clients will be informed if repairing work is required, quotes will be given before additional work taking places.
Good work spoke to Trent and he was talking about your car. Saw your car outside too!
Copy pasta
In for a tune with Trent today but got an issue I need to fix
So in for a tune on the new turbo.
But there is an underlying problem with the car. At this stage it may be the injectors. So we are going to pull them out and flow test them
In coming to this analysis we switched to e85 fuel, so will probably just stick with e85 fuel.
At this stage the car makes 315rwkw at 4,500 rpm. Trent thinks it will get close to 400rwkw once the issue is fixed.
ahaha yeah looks pretty beaten up atm. Was that your car the black one in the dyno when I was leaving?
What turbo are you running on it now?
ATR45. So a copy of a 3582 xr6turbo. Slightly smaller than a Garret 3582.
Internal gate. Stock manifold position
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
