Posting a little update. This is the SS2 based ATR28 turbocharger with a even larger turbine. This particular one runs off ceramic roller bearings. Hopping to get 300rwkws+ with 20psi by 4000RPMs.
That housing is nearly all turbine lol Surely that cant have a good nozzle area? You must have lost heaps when machining it to suit the turbine.
That's fine. You just need another one of my patented unspacers.
But seriously.....what size turbo is that manifold designed to hold up? For it to place it so close to the cam cover is a bit, um, wrong.
Edited by GTSBoy
Well I purchased it off someone on this forum stating it was for an RB25 and he planned to put a GT3582 on it. I bought it unused, maybe there is a reason it was unused....
I'm on my mobile at the moment so I can't search but surely it's not the turbo that's the problem? There would be pics of peoples high mount SS2 but I can't find them.
It would have to be the manifold I'm sure of it.
lol that is very wrong. The turbine is in a standard T3x patterned housing, means other T3s will have similar issues. I use Brae high mount and fits perfectly.
Definitely a problem with the manifold. I would say the jig used to make it would likely be overused and out of shape.
There is nothing unusual about the size of an SS2, its definitely not going to be much larger than a GT30/35 based turbo.
I have an ss2 low mounted on a 6boost manifold with no issues. Comp housing is a bit close to the engine mount bracket but no issues at all
That manifold is odd. If someone was going to run that sort of manifold with an ext wastegate an ss2 should not be an issue at all. Looks like youd need to have a stock turbo for that to work......
If its a 6boost then call or email kyle. Probably best to email him with some photos and give him your number. He might be able to give you an answer or organise an exchange of some sort
I think it make similar power as your GTX3071 hopefully with better response. If that works well I will enable VCT.
Taking consideration that my SS1PU made 30kw less than your test car (at the time on p98 w/cams) before it was maxed out, I am going to apply the same reduction to my GTX. In the end my car pulled the MPH to support happier numbers so I believe that's fair.
Just putting that out there before we compare the results from the 2. My car is a complete back to back, I have only changed the manifold and turbo. Considering I went to T3 high mount I should have more lag than you.
We will compare results soon enough. I'm sure they will either drive sales for yourself or give you something new to strive for
Most gtx3071r I've seen on sr20 are slightly laggier than the old gt3071r
Gt3071r 20psi by 4000rpm
Gtx3071r 20psi by 4500rpm
Both highmount t3 .63ar
But while the gt3071r will struggle to make 300rwkw on pump98 the gtx3071r will make that quite easily on 20psi and a lot more with more boost and e85 330-350rwkw
My results on my car with the ss1.5 were almost the same but I was on e85 his was one pump
For 20psi boost I made 250rwkw and he made the same but on pump 98
With 5 psi more down low and taper up top he got 270rwkw but he has a aftermarket manifold and step 2 cams mine is std manifold and poncams
E85 usually gives a 20kw gain on the same boost level
The difference would be the cams. I've compared mine with few that has Pon cams at Trents, The BC cams are making in average of 15kws more mid-top while the pon cams has 15kws more in mid-low with better response.
The GT3071 on my car hits 20psi by 4250rpms at 250rwkws, feels laggy down low.
Another update this is my latest ATR43SS2 turbocharger.Compare to the current one. Compressor inducer has been increased by 2mms, while the turbine inducer and exducer has been increased by 3mms. This particular one is expected to be maxed out at around 390rwkws on E85.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
