Yeah hopefully does it easy
Actually while I'm on the phone for work, on here and playing with the gate
Whats the best way to plumb it up?
It also looks adjustable, yes or no? Would be handy if I could set the boost via the gate instead of either trying to find my Greddy E-01 or buying a new one.
Nice result Jared, Are you sticking with 98?
Will prob stick with 85.
Get a better fuel pump. Jump to ~18-20 psi and see what happens.
I may need to lose the nistune, tuner is saying it a tad hard to work with at this power
Hah, i kinda launched it as that run i was waiting for so long because a Camaro broke down and they lost power to timing lights.
So i just gunned it.
Heres me beating a 585 hp f6 (
I think he backed off, as the next time i went up against him he beat me by half a car length.
Any dyno reading from that tune? The SS2 on Jared's car is the Black edition, with the latest compressor and larger turbine. It should be making power easier then the previous version.
A result sent in from an SS1PU customer. This is the latest version also that has a different compressor that is engineered to hold boost better and more top end.
It is running on E85 maxing out fuel pump. Peek of 301rwkws @ 17psi. With plenty of mid range.
From customer's feed back letter:
R34 GTT (Stock Motor)
Supporting Mods
Blitz FMIC Return Flow
1000cc Injectors
Standard Airbox (Panel Filter)
3inch Bellmouth Full Exhaust
Z32 AFM
Walbro 255 Fuel Pump
SS1PU (latest model)
Scotty's Alloy Intake
CALTEX E-Flex
301.8 Rwkw (18psi peak, drops off to 17psi holds well)
Supporting Mods
1000cc Injectors
Z32 AFM
CALTEX E-Flex
Is that wheelspin or is it an auto?
It is a manual. Don't know about wheels spinning, this is a responsive turbo that reached 20psi by 3500rpms while tested on my car.
The older versions has a boost tapper behavior up top maxing towards 260rwkws, I have had that fixed, also resulted in greater top end power. Pulse racing has sent in a feed back mentioning it is the best bolton turbo he ever had on dyno.
Another update this is my latest ATR43SS2 turbocharger.Compare to the current one. Compressor inducer has been increased by 2mms, while the turbine inducer and exducer has been increased by 3mms. This particular one is expected to be maxed out at around 390rwkws on E85.
Ball bearing version of above SS2 turbocharger. Its now fitted into my KIA.
Very tight engine bay.
Hopefully making 220fwkws on unopened NA engine with stock auto. will update result once tuned.
Just re-cap.
Its a 2009 Kia sportage, factory G4GC 10:1 compression engine, Auto.
Return flow cooler
650cc injectors
Adaptronic E420D ecu
HPVA 50mm external gate
Brae Manifold
3inches turbo back exhaust.
Currently pulling 200fwkws on E85 at 14psi.
  • Like 1
man that ball bearing version of the SS2 looks awesome, keeps spinning and spinning and spinning and spinning.. can't say the journal one does that haha
Oh yeah, been touching up my tune, here's my map (for those DIYers who are interested).
Can't seem to squeeze anymore out of the stock injectors, boost now at 1.2bar with SS2, externally gated.
Pulls like a freight train in 3rd, and I'm able to get full boost in 5th at 3600rpm :)
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
