Yeah hopefully does it easy
Actually while I'm on the phone for work, on here and playing with the gate
Whats the best way to plumb it up?
It also looks adjustable, yes or no? Would be handy if I could set the boost via the gate instead of either trying to find my Greddy E-01 or buying a new one.
Nice result Jared, Are you sticking with 98?
Will prob stick with 85.
Get a better fuel pump. Jump to ~18-20 psi and see what happens.
I may need to lose the nistune, tuner is saying it a tad hard to work with at this power
Hah, i kinda launched it as that run i was waiting for so long because a Camaro broke down and they lost power to timing lights.
So i just gunned it.
Heres me beating a 585 hp f6 (
I think he backed off, as the next time i went up against him he beat me by half a car length.
Any dyno reading from that tune? The SS2 on Jared's car is the Black edition, with the latest compressor and larger turbine. It should be making power easier then the previous version.
A result sent in from an SS1PU customer. This is the latest version also that has a different compressor that is engineered to hold boost better and more top end.
It is running on E85 maxing out fuel pump. Peek of 301rwkws @ 17psi. With plenty of mid range.
From customer's feed back letter:
R34 GTT (Stock Motor)
Supporting Mods
Blitz FMIC Return Flow
1000cc Injectors
Standard Airbox (Panel Filter)
3inch Bellmouth Full Exhaust
Z32 AFM
Walbro 255 Fuel Pump
SS1PU (latest model)
Scotty's Alloy Intake
CALTEX E-Flex
301.8 Rwkw (18psi peak, drops off to 17psi holds well)
Supporting Mods
1000cc Injectors
Z32 AFM
CALTEX E-Flex
Is that wheelspin or is it an auto?
It is a manual. Don't know about wheels spinning, this is a responsive turbo that reached 20psi by 3500rpms while tested on my car.
The older versions has a boost tapper behavior up top maxing towards 260rwkws, I have had that fixed, also resulted in greater top end power. Pulse racing has sent in a feed back mentioning it is the best bolton turbo he ever had on dyno.
Another update this is my latest ATR43SS2 turbocharger.Compare to the current one. Compressor inducer has been increased by 2mms, while the turbine inducer and exducer has been increased by 3mms. This particular one is expected to be maxed out at around 390rwkws on E85.
Ball bearing version of above SS2 turbocharger. Its now fitted into my KIA.
Very tight engine bay.
Hopefully making 220fwkws on unopened NA engine with stock auto. will update result once tuned.
Just re-cap.
Its a 2009 Kia sportage, factory G4GC 10:1 compression engine, Auto.
Return flow cooler
650cc injectors
Adaptronic E420D ecu
HPVA 50mm external gate
Brae Manifold
3inches turbo back exhaust.
Currently pulling 200fwkws on E85 at 14psi.
  • Like 1
man that ball bearing version of the SS2 looks awesome, keeps spinning and spinning and spinning and spinning.. can't say the journal one does that haha
Oh yeah, been touching up my tune, here's my map (for those DIYers who are interested).
Can't seem to squeeze anymore out of the stock injectors, boost now at 1.2bar with SS2, externally gated.
Pulls like a freight train in 3rd, and I'm able to get full boost in 5th at 3600rpm :)
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
