Here is what happened. A mate of a customer shown interest of buying the test car, welling to pay my asking price but requested for a compression test at a known workshop that few of my customers went and have sent me a number of jobs in the past. (Not chequrered tuning or any one from the SE).
The car was perfect, drove in to the work shop. They did a comp test, all came up to 170 psi. After the plugs were put in, crank and straight way there was a knocking sound in the engine. The mechanic "one of my customer" also found a missing coil pack bolt that I know it was not missing from start. I'm 90% sure some that was dropped into a spark plug hole, but the shop owner tries to convince me its a knocking sound from end bearings. LoL. With oil pressure gauge alive and sender gage disengaged, it obviously makes no sense. I'm f*ken pissed off at this point but did not wish to turn at all those familiar faces. So that was the end of it.
I'm leaning towards of doing some work on Rb20dets. After all that's the only engine that I've missed out and the project will be very challenging.
90% of people drop rb20's in the bin. So I wouldn't bother.
What I'm interested in is RB25Neo, not DET the NA ones.
Higher compression, better response, on E85 with mild boost.
Mention is to Trent, see what he says ?
couldn't you just put a bore scope in the cylinders and see the marks it would have made as well as throw the compression tester back on there and show that its no longer the 170 across the cylinders to prove they f**ked it and 'you broke it you bought it'.
also why didn't you do the compression test yourself in your shop?
The buyer only trust that particular workshop, no one expected this issue. The car drove perfectly to the point when it was powered up again after the comp test.
The comp tester shown very little change after, its a metal "bashing around" sound from the upper half of engine. Work shop had a broken scope that can't be used. Owner offered $3.5G to rebuild that engine, to me the rest of the car's too rough to have that sort of money spent on. Buyer how ever was happy to take the way it is with $4G discount, his offer was accepted, and I'm over with it.
I'll be looking at few more skylines this week, and hopefully be back on projects shortly.
I guess the point of bring that up is my RB25det NEO did not broke because it had excess boost at it. The failure was totally none performance related. They are excellent engines.
Don't bother with rb20s.
If you're going to draw a line under RB25 turbos, which probably isn't the worst idea, I'd concentrate on XR6 turbs or perhaps something for our retarded VG cousins.... sorry Fairlady and M35 owners.....even the designation VG sounds a little retarded....
Stao, how many rb20 hiflows and atr43ss1.5 do sell a year? I bought one of your hiflow second hand and it is a bit laggy, but if you go ahead and develop something really fast spooling for an rb20 I would be interested.
That or a direct fit rb26 solution. The only options people have are -9,-7 and -5 reallly.
-9 resonse with -7 power would kill the market with direct fit.
  • Like 1
Wow thats totally bs stao.. i belive youv been in the business long enough to know what your talking about.. but there are plenty of people out there that arent as genuine unfortunately. On a side note im with most of the gang here i wouldnt bother with the rb20.. maybe rb30 turbos? Or some more rb26 bolt ons.. either way im happy
Name and shame that workshop. What a dog move.
yeahhh nah for the sake of the forum that can't be done. legal bills etc etc
anyway I vote twin-cam RB30's next! (please, i'm building one)
  • Like 1
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
