You could be retarded like me and buy a standalone ECU for the gearbox..
Or be like my current better half who just learned to drive manual
Ur right dose pipe you can pigy back tho has to b a good stand alone tho i did hear you can use a r34 computer and go nistune to how true this is im unsure
R34 like S2 Stagea has a different plug. People usually just get something like a Greddy Emanage, HKS F Con or even a Link and interrupt the appropriate wires.
Adaptronic e420d are cheaper in the long run and Tao has the best price in Australia. Msg Tao and ask him how much.
The greddy is old tech and you need to buy a whole lot of add ons to get to where the adaptronic is.
Tao, my early 2012 SS2 appears to have done a compressor seal. When I pressurized the manifold it leaked out almost the whole way round the seal.
What's it gonna cost to fix that and any upgrades you would recommend?
The seals in turbos steel C clips. They are not an liquid tight seals. Unless there are measurable back n forward play, those seals won't wear, and if its also not leaking when the engine is running its most likely to be alright.
Most of turbo drain system relays on gravity. When crank case pressure is applied, oil will be forced out of both compressor and turbine seals.
If there is an measurable back n forward play it would require an rebuild. Assume all it needs is an bearing kit, I will charge you $100 to carry out.
The current SS2 is very different to what it was, it makes a lot more power without losing response, specially for externally gated application. But that will require a new build and I'm happy to look after you on the pricing.
Ah good, there is no play in it, just weeping air out the seal when compressor was pressurized. Wasn't leaking enough to hear but could see when spraying soapy water on it.
Found 7 boost leaks and 1 vacuum leak on the car so hopefully it's a completely different beast now.
Thanks for the offer but I'm quite happy with its performance and will stick with it.
Edit- and the crankcase circuit wasn't pressurized so the oil seals are fine :)
Alrighty update time, I've installed the new revised SS2 with the Ceramic Ball Bearing CHRA... and... holy fuark me it's amazing.
I was too lazy to touch up the tune but it's rich enough to be thrashed *cough* I mean tested lol.
I'm now able to get nearly 1.4 bar in 2nd gear! where with the old circa 2012 SS2 it would barely get 1.2 bar in 2nd. In 3rd shit just gets silly, I'm getting nearly all 1.6bar in around 4200rpm according to the inaccurate OEM tachometer.
I'll plug in the laptop for some logs soon for those data junkies.
A few things with the new CHRA, it's so much easier to install as you're able to bolt up the turbo without needing to remove the front cover like the old SS2. However the turbo sits lower so I need to cut my dump and weld it back up also the oil return need a slight bend to line up other than that it's nearly plug and play.
  • Like 2
Drifting video from Jason.F's R31 Wagon. This particular project has a very unique CBB turbo build on getting most reponsive 320rwkws out of none VVTI 1JZ. It has been a challenge dealing with back pressure and took a few try to get working.
  • Like 4
Sounds awesome, glad someones havin some fun...
Vids of skids and teh su.. su.. su.. sututututuutut...
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
