^ lol... maybe I'll use a 3" intake pipe and add in more bends.. that usually gets the suuuuuuuuuuuuuuuutuuututuutut going LOL.
Anyhow, some real world facts to back up the results.. errbody likes timing maps, logs and dyno print outs LOL
Power Run Log (rename it to .csv)
final pwr.txt
Timing Map & Compensation Map
the reason it's so ridiculously advanced when there's loads of boost is because the normal 98RON runs crap all timing at high boost areas so I don't blow the motor to bits when it's on 98RON and accidentally run a little too much boost.
Andddddddddd Dyno Sheet
  • Like 7
Awesome result mate
I drove it before the tune and was already like a light switch when power come on
But the ext gate noise just made it feel that bit faster
Any plans to take it to the drags ?
Looks like that exhaust aint too bad as power isnt noseing off and boost is rock solid
500hp stock bottom end
It's so quiet now man, we could have a full conversation when it's on noise... I didn't even need earmuffs in the dyno room!
Of course man, I'll take it to the drags one night for shits and giggles, I'll give you a heads up too!
Well the entire system is 3.5" till the rear muffler at 3.25"... the front section of the cat back was chopped off and replaced with a 3.5" Hurricane round muffler.
Exhaust system wise, I think it's flowing just right.. I have the option of dropping the gate plumbing back into the system.. but with the power achieved and the boost response I doubt that there's much back pressure.
Some updates on the ATR45SAT CBB Turbocharger. made 336rwkws @ 22psi on Pump 98 fuel, internally gated bolton.
Sorry not the prettiest looking. I just can't get same power out of fancy looking bits.
This turbo is big for a 3 inches turbo back system on an R34 GTT. I can't get much more power then the G3 SAT with exhaust connected. Result above was obtained from front pipe dropped before the cat. it would be a very nice turbo to run on an external gate off an factory exhaust manifold.
Thanks for the plot. Looks pretty accurate.
Here is another piece of data from last week's dyno run. It is an direct comparison of latest SAT CBB turbo assembly vs Plan bearing assembly In RB25det. Same car with same turbo, the only thing that has been changed is bush bearing to ball bearing. The differences made in response was 300RPM and Car's reaching peeking higher boost on lower gears. The CBB result was trailed back in 2012 using a much smaller shaft wheel assembly while its end result is not as tangible, the effect appears to be more tangible depending on the size of the wheel assembly or the total rotational mass.
Interesting - Would it be possible to get mine redone with the different bearing for better response? If so how much would it be?
Re-highflowed one of blown Ebay's Highflowed OP6 turbocharger with one of our G3SAT Ceramic Ball bearing CHRA, Did a actuation test using their billet casing actatuors supplied. Appears some "pretty looking" parts does not work as well as how they they looked.
That billet 38mm internal gate is part of our G3 high flow profile, not what originally came with the turbo.
Photo one shown full actuator travel using ebay's actuator.
Photo two shown full actuator travel using one of our standard 14psi actuator.
Stao, are you still of the view that the 21u highflow would be too responsive with the ball bearing cartridge and create surge or have you tried it.
Still looking for the most responsive turbo for r34gtt and was looking at the 21u high flow with high flow actuator
The 21U is already super responsive in bush, there is no reasons to make it ball bearings as I've already trailed and compared. for R34GTT the best result I've trailed was G3 high flow using CBB cartridge with high pressure actuator.
S15 SR20, 250,000km old with full service history from older age owners, aust delivered.
Standard motor
headstuds and mls head gasket
BC 264 vtc delete and valve springs, rocker stoppers
6 boost, 45mmex gate
1000cc inj
walbro 460l
E85 plus pre turbo water injection
Hypergear Td06 20.5G 8cm T3 rear
19psi 314rwkw
23psi 366rwkw....power is still climbing..its just hitting the rev limiter
Tried to turn it up at end of night...made 386rwkw...at 28.7psi...lol...at only 5800rpm....then started misfiring.
Plugs where done and it was getting late in the night so we stopped for now..nice little turbo
We used a china cast t3 mani before and 38mm ex gate...went from 314rwkw at 23psi to 314rwkw at 19psi from just those changes to 6boost and 45mm..and spooled 300rpm quicker
To give you a idea how dyno reads, the best 0p6 hypergears hiflow skyline on 98oct has done 290rwkw at 19psi on this dyno, best skyline auto has done 260rwkw on 18psi on 98 oct
Now its onto getting the atr45.5 test car up and running.
cheers
Jase and Darren
Edited by jet_r31
  • Like 1
Sharing my 21u
That's monster power but seems to come on a bit late, if I'm reading it correctly? Full boost at 4.5?
Pretty sure efihardware and kudos do plugs here in Australia. Before that I purchased my VCT plug from wiring specialities in the US. Was only $6-7 I think.
  • Like 1
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
