1. Its PWR so ofcourse it will get fabricated right the first time. On time too. :P
lol, I see you have given PWR exact measurements and application details before with an order only to have something completely wrong turn up. I thought me and the 300 other people I spoke to were isolated incidents... :huh:
so you order a custom rad. give them all the details, maybe even a cad drawing if you are so inclined. they say 10 days to make. 20 days later you get a box unannounced. inside it is a radiator. completely different to what you wanted. you call and say WTF? they say, "oh" sorry, do you want to keep it for 20% off? we don't really want it back? you say no. they say ok send it back. they then say, oh, we have the one you wanted here off the shelf, we can send tomorrow... WTF??? send the rad. this time it is right. then they might send you another one and bill you twice just to keep you guessing. lol.
  • Replies 615
Posted Images
Gees mine wasn't even that complicated.
Give me one for a stock R32 Gt-R I said. So they did. Sort of. I mean, to be fair some of the dimensions were correct.
I got it fixed locally as I ran out of faith that they could get it right. Admittedly I didn't want to wait for it to go back & forth to Queensland from WA & I got the hump after they told me my car was what was wrong.
So I dunno. They do some good work but their quality control as far as building the things as per the drawing is well, forum rules & all that. :P
Edited by djr81
:P:huh::P:rofl: :rofl:
We supplied a CAD drawing with exact specs and measurements in millimeters, but I don't know how accurate the end result was...
Perhaps John did the measurements to check?
well they have made a few of those rads now. having said all that their gear is top shelf. once you get through the standard order process of receive, swear, return, receive, swear, return, receive, rejoice, use. then it's all good. :P
yep the PWR rads with oil/coolant heat exchanger are the way to go. when you look at the price of a nice rad like a koyo and a good oil cooler like say a trust kit then the price of the PWR all in one solution makes a lot of sense. and like DJR81 pointed out you then have the passenger side duct free for something else like CAI.
'big' hp = cant fit big enough oil cooler into radiator, need to use 21row or use 2 oil coolers 1 in the radiator and 1 external
thick fmic + street driving/low air speed = not ideal to use anything thicker than the 42mm (low air speeds when in traffic/start stop stuff the air cant pass through the fmic and cool the radiator quick enough)
twin pass can only be made in ~55mm radiator, bollocks if u have space constraints (i.e crank driven oil pump is in the road)
info straight from PWR
Luckily my engine is stock :P
Nice work cleaning up the chassis rails mate,,,I was having kittens when I saw dirt.
I've used PWR on 3 occasions with drawings and each time they came to me perfect. Must be because I'm a nice guy.
Andrew have you thought about running a fuel cooler?
Neil.
Nerp... Not as yet...
I'll get to the details like that further down the track... Right now, I'm just concentrating on the basics :(
Not much action... But we should have some shiny new brake hardware photos next week :)
Custom header tank
Clutch line with the dumb delay valve mechanism - bin!
New braided clutch line = yay!
1kg weight saving......... Priceless. :D
It's there to smooth out the pressure of the clutch line, so the result is a smoother activation and deactivation of the clutch.
Obviously designed for road use, but many people get rid of it for road use too, as you lose control and feel over the clutch pedal.
It's there to cool the clutch fluid to prevent boiling. With the stuffs removed I usually have to bleed the clutch after a drag or track day.
BTW where did you get your braided line from?
Edited by 9krpm
Give Tim a call at Unique Autosports... He'll source one for you...
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
    • Oh sry i do not know if i used the term right. What i meant is upgrade the internals and keep the housing. That is not "hybrid"?
