you need to check the regs for the series you want. IPRA (3J) for instance does not allow cage outside the cabin. 3E does. 3D has specific requirements as well (side intrusion etc).
Targa Tas has moved away from CAMS regs....and from a quick look this cage doesn't meet CAMS regs because there is no diagonal at the B pillers, just a lateral bar.
Looks great though and the support points where mutliple bars meet are the goods
i HATE how these motorsport inspired build threads have been moved. I only visit the motorsport section (well mostly) and IMO moving to here has killed the threads.
Just some feedback for you mods/admin.
me too :D unfortunately i'm not a dictator though and there was some support for this section. god knows why but it's where we are at now...
cage looks excellent btw. :D
oh, and suspension wise on a dollar for performance ratio I reckon it's hard to go past a set of Murray's home built proflex. considering the quality of his gear, and the benefit of aussie support for revalving, repair, or replacement it's a great way to go. they are not particularly cheap but considering some of the options run up and over $10K per corner his prices are quickly put in perspective...
well it's been pissing down today, so i couldn't get pics. i'm planning to take the guards off and do some seam welding tommorrow, also after helping damo with his car last weekend, i'm going to remove all of the body sealent, as all it seems to do it seal rust in.
What ben is trying to say is he is gonna see if he can weld better than me then if not ill be seem welding 2 cars. or he can come and finish mine off.
unfortunately my seam sealer had a special one way water absorbing quality. every where it is the rust will follow.
So envious of the "Two Bens R32 Racing" GTSts :P My thing is sitting idle still trying to be a road car. Love the cage. Is YT reasonably priced as in Melbourne that would be a $4000-6000 cage!
I so want a track car but stranded in friggin India and am changing my mind every 3 days between Caterham, my R32, another R32 or doing what normal people do with the money and buy a Hou...err 2002 Vette :)
The cage was in the $3500-$4000 range. I'm really happy with how it came up.
bloody tassie weather, i preped the front of the car ready to weld, and then it started pissing down again.
pics uploads are being fail atm, so i can't upload pics yet :P
yay pics are working again
preping for welding before the rain...will probably need to go over it again tommorrow
more pics of the cage
reson for no main hoop diagonal is that yt only puts them on on request (unless its cro mo), i spoke to him about it, and it's a pain in the arse for putting helmates in the back between stages, and nursing them between stages isn't much fun. unless you have a big hit on the top bend of the main hoop, the other bracing will pick up the force. he's made a lot of cages down here, and quite a few have ended up in the trees, so i was happy with what he said.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
