  • Replies 201
was on the eastern free way heading towards the city and all i could see ahead me was dark as clouds! then 2mins later a few drops...2mins after that bang fkn hail storm whiile i was on the fwy...everyone nearly had a massive stack...n everyone parked on the left to take cover from those big ass windows on the left before donny rd exit. hope my cars alright havnt had a chance to look properly coz its all wet.
just got the gtr back
coped it bad in glen waverly
roof, bonet and one front guard are all dinted up im so f**king cut i almost cryed
i think its going to be cheaper to sand, bog and repaint the f**ked pannels
ive got 6 on the roof, 3 on the guard and about 15 on the bonnet
i wanna kill myself
Edited by V-Spec
It hit rowville very bad! Luckily my car was elsewhere and undercover. Most of the neighbours cars are rooted. My sisters S13 has smashed taillights, smashed windscreen, smashed rear window and no joke, about 100 golf ball sized dents.
The house is a mess, the skylights smashed, and the garden is ruined.
I feel very sorry for all those affected. My girlfriend left her car at burwood kmart (gets on the tram to go to work), she is on her way back to it now. I pray that it isn't too bad.
Edited by lukebaldan
was at chadstone, 5 min before storm hit visiting mates. I left going east on princess hwy when i got the call saying get to cover!
made it all the way to fountain gate b4 hidding in car park for the next 30min!!!
Just had car built and been on the road for 1 week, close call!!!! :D
sorry to hear others wern't so lucky
muhahaha time to buy up some financial writeoff cars. f**k yeah. I <3 hailstorms.
there were a few hailstones in our front yard. 32 and s14 were in the garage, and the hailstones weren't big enough to dent the ceffy and maxima.
puppy copped a hailstone to the back while taking a dump in the front yard... altho he spent the rest of the arvo chasing hailstones and licking ice. retardo dog.
LMAO my dogs used to hide when it rained
driving back from our shop when it was coming down hard in the north. f**k me. was that a nervous drive for an L-plater
Had golfball size hail in dandenong. All i could do is watch my lights flashing from the car alarm, couldnt hear it at all from all the hail noise. Havent looked over the car, dont want to upset my self by fiding dents/chips on my 2month old micolour respray :D
My parents brand new car got a belting in ferntree gully where the hail was size of tennis balls.
My friends in rowville have smashed car windows and holes through their satelite dish O_o
been told you need to say you were driving when it happened to claim insurance or something like that. . . might be wrong.
and if hail damage is too bad i think it gets written off.
a few workshops on my street got a bunch of cars from dealerships couple years ago when another storm hit, hail damage was so bad the cars where written off. . .
these guys fixed the cars and now they have been sold. :D money talks i guess.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
