To my understanding the 6870 is the biggest of the mid frame precision, I know of a few 2.8s with 6870s.
From what people have said the 6870 on a 2.8 will have similar response to a 6466 on a 2.6 but make closer to 850-900hp at the wheels
I have spoken to one person with one and he says he’s all in at around 4100 with a 1.15 rear on it
The logic is that with my new head and inlet setup i should retain the same response and make more overall power on the 6870
It is also suggested I may hit the back pressure wall on the 6466
All in all I am in a holding pattern until seeing what the 6466 does on the new setup and just seeking results on a 2.8 6870
  • Like 1
10 hours ago, BK said:
 If so on track isn't Simon R. still quicker with a 6262 on a 2.6 ?
first of all, how much did Simon pay you to say that 😁
The debate on that is largely irrelevant as both of us run around 550/600whp on the track, as opposed to 800+ when doing other events.
  • Haha 1
And you dont even need the 1.15..
Even in a 3.0 they are all in compressor wise on a 1.00
Far out man, a responsive wheel 900hp !
I can't even comprehend that as being realistic. Someone really needs some 6870 results here
  • Like 1
  • Haha 1
It is possibly realistic depending on what boost number he is talking about and what size engine, how long it's loaded to achieve that or maybe how much nitrous.
For what it's worth this dyno plot is of a RB32 with VCam running a 6870, it's going to be harder to make a 6870 come on quicker than this on a sensible ramp run on a dyno without nitrous.  Definitely not with an RB28
Edited by Lithium
Me either it’s why I’m asking for other people who have done it.
I would be looking at the 1.00 rear if I did it. At the moment  I’m looking to put a 1.00 rear on the 6466 and thought I’d ask about the 6870 because of the number of people suggesting to go that way
You tune with JEM right ? What did they say ?
14 hours ago, BK said:
Thanks for that mate. So there is some merit to the guys suggesting to maybe skip the 6466 stage in favour of the 6870 in the first place ? This was my original intention.
I know the 6870 will make more power, but surely that will translate into a slower car everywhere else but the strip ?
Dont know
They all have there place.. The 6466 is still the best allrounder.. Its a epic little turbo. Slower everywhere else could depend on style of circuit you use?.. Comp, camshaft/transmission type  even tyres used for corner exit.
So could be merit in it.. But apart from efr the 6466 is hard to top
I haven’t got Facebook to be able to get it, I found it using the mrs computer and it was the usual photo of a screen that’s impossible to read so I went off his comment further down the page
2 hours ago, r32-25t said:
I’m building a street car that I can take roll racing, not a car dedicated to winning roll racing. there’s a difference!
The only difference is turbo?
You're going to be off boost until 5,000rpm anyway....so what difference does turbo size make at this stage?
Save yourself the money - buy the biggest turbo possible - because I guarentee you won't be happy with the 6870 in a few months time....
Realistically a 2.8L with a 1000+hp turbo isn't gunna be THAT streetable. It kinda puts you in "the middle" as it's not going to be good on the street & it's not gunna get you anywhere in roll racing either.
Obviously this is just my opinion and no doubt a 650kw car is gunna pull like a freight train once it wakes up!
 But making a car that's gunna be laggy on the street to compete in the 2nd biggest dick shwinging contest after WTAC every couple of weeks/once a month is going to ruin the car for all those other drives you will take it on.
I think you're off ya head ditching V cam and the 6466 man.
6466 + vcam + 2.8L + sequential will make for a brutally fast/responsive car thats gunna do street duties, SAU cruises amazingly well! But realistically it ain't gunna change your roll racing result at the end of the night cos you're going home once the big boys come out to play anyways.
 All you're doing is sacrificing a f**ktonne of low/midrange & overall average grunt for a lazy 50kw up top dude? At the expense of 80-100kw of midrange grunt  and far more drivability off boost ditching V cam.
Ditching V cam on a street car is a huge mistake. You've felt the gains its given you and you're basically going 2.8L to give you the low down grunt V cam has given you. You're taking a big sideways step with shit cams and no skinny cam. Bigger cubes & v cam is the only logical choice for a street car. All you're building is a top end screamer in the "guise" of a street car imo.
  • Like 1
  • Haha 2
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
