4 hours ago, ActionDan said:
The pin/hinge and adjusting knob interest me, how have you got that setup and where'd you source the bits?
It's just a cheap one off Ebay-
https://www.ebay.com.au/itm/331881988969
I chose this one as it comes with the thread in the base of the mounting post.
I bought a threaded rod and nuts if I need a longer adjuster.
  • 1 year later...
It’s just dumb to have such similar designs that are only half compatible…
This is my latest tool “investment“.  I’ll use them for everything I’m assembling that I take photos of to put on Insta (ie. nothing….)  On Project Binki they call them the “show spanners!”
I’ve wanted them for ages so finally convinced myself they’re worth it when they’re actually totally not but meh. 🤷🏼‍♂️
  • Like 1
On 28/12/2021 at 1:27 PM, Ben C34 said:
When you realise how Phillips head is designed to cam out when the torque is high it is f**king ridiculous it is still in use.
Must be cheaper to make...I would have thought that they would all go to allen key head or even torx...wish that they did, its easy to chew out a phillips/posidrive/jis head with a drill or impact driver.  Both doing up and undoing, lost count of the times I've had to use a dremel and cut a slot into a screw or bolt then 'shock' it out with a manual impact driver to get it out.
FYI for info on the phillips/JIS/Posidriv/Torx/etc options  check out https://en.wikipedia.org/wiki/List_of_screw_drives
Looks like the 'Vessel' brand does JIS, anyone have other suggestions on brand (or shop)?
https://www.sealey.co.uk/product/5637750680/4pc-jis-screwdriver-set
  • Like 1
But, where do you ever come across JIS fasteners? Not in a Nissan thankfully.
And those long spanners are nice to use, but they just aren't feasible in most tight locations.
They’re like most specialty spanners ( S, C, stubby, ratcheting, high offset, etc) they’re shit for 95% of normal spanner jobs and absolutely essential for the 5% of situations where nothing else works. THAT is why you buy them, not for the presumption that 1 spanner fits all.  I have a stupid amount of different spanner sets now of which I will probably only use about 10% of but I’m sure you’ve been in a situation where nothing fits and it sucks balls.  I’ve wasted hundreds of dollars to avoid that incredibly rare situation but I think I just like collecting spanners! 😂 I should take a pic of all my different sets as I think I might even scare myself once I laid them all out….
  • Like 2
  • Haha 1
Have not seen many electrical tools mentioned so here are two I like. I'll see what else I can come up with.
1. Connecter depinning tools. I often see people stabbing away with a flat screwdriver only to crack and destroy their old connectors.
2. Cable tie gun. This will tighten and cut cable ties in one shot. Very practical and quick when you have 100's to do.
  • Like 2
  • 2 months later...
Wait until you realise there's now a fastener/driver made called Torx Plus, and a Torx driver fits Torx plus heads. But under hogh torque will strip the driver or head...
  • 3 weeks later...
Yep, they basically have a double thickness star point.
I swear they purely make different fasteners so they can sell more tools.
  • Like 1
  • Haha 1
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
