Hehe nice. I wanted to hug it when I first saw it, then maybe see if I could eat it.
Sadly though - not sure if I am going to ever get a chance to fire it up - looking at another option that could have me abandon the entire build... :ermm:
Is that an RB30 block in the background of Chris's engine room?! Whats he doing! lol
Why would you stop so far into this build? It seems everything has been done properly from the outset, the end result wouldve been just awesome.
Believe me I know how nuts it sounds and it kills me to be doing it.
Problem is I am still a good $25k+ short of rolling up to a start line. If I cut my losses now while most of the parts are still brand new and in their boxes, motor is new etc, it is going to end up costing me the same or less to get into an already fully developed car, built to the rule book, with proven pace, that is also pretty fresh.
Most of the parts will be sold off.
Trying to work out the best thing to do with the shell. Will probably still put it in paint and get it for the most part back together so it's an attractive option for someone wanting to build a caged car. If I can convince the missus that nobody wants it for long enough to get enough cash back together I might end up keeping it. Still very attached and would love to see it back together in my garage.
Anyway - no signed sealed deal done as yet but its in the works.
that black wrinkle paint job on the motor came up mint
did you spray it? if not where did you get it done?
great build thread
The guys from Racepace did it for me. It's just the VHT wrinkle black you get from Repco, Supercheap etc. Looks awesome.
You need to make sure you do it in warm weather and put enough of the stuff on otherwise it can come up a bit weird. Even better if you can get it in a low bake oven - my spray painter showed me a strut brace he did in his oven and it came up really sharp.
  • 1 month later...
Some more progress. Mick was almost finished cleaning up the underneath when I dropped in.
The rails had the usual distortions from years of jacking / hoists, these were pulled back out, cleaned prepped and zinc primered, and for the fronts a 1.5mm plate tacked over the top. Holes will be drilled where the factory ones are to make sure they still drain water correctly. The car had been jacked up from the rail rears as well instead of the diff, so these were pretty ugly but looking perfect again now.
The sill panel seams and roadside tyre change jacking point that was buckled in have also been completely repaired. As of Friday night it should all be sitting in chip coat now!! Going to get a good bake first before it comes back down off the rotisserie just to really make sure everything is dried out, then work on the interior and panels will begin.
I have decided I am still going to get this thing screwed back together properly and then see from there if I can afford to keep it, don't know how I could possibly sell it though.
Some photos:
post-12551-0-52899000-1310942870_thumb.jpgpost-12551-0-29562600-1310942877_thumb.jpgpost-12551-0-64951300-1310942883_thumb.jpgpost-12551-0-72561100-1310942889_thumb.jpgpost-12551-0-96379600-1310942894_thumb.jpgpost-12551-0-07130600-1310942902_thumb.jpgpost-12551-0-91922100-1310942907_thumb.jpgpost-12551-0-29702200-1310942914_thumb.jpg
  • 1 month later...
So what is happening to the bus these days?
It has been put on slow-mo for now.
Bought Snowy's white 34 so getting out and about in that at the moment, entered in Targa High Country and Targa Tas next year so funds are all aimed at that at the moment.
It is however going back together an intended, with the Racepace motor and GT-SS turbos. It will be my tribute to the car that I love so much, and I will get it out to track days where there is minimal risk of damaging it's pristine state!
As much as I would love to drive it in a Targa event, it's kind of a better outcome 1) because it is going to be another one of Mick's works of art once finished that I couldn't bear to scratch, and 2) I can have some freedom with it from rules to do some crazy stuff down the track.. thinking v-cam, maybe some of these newer gen turbos coming through and possibly a larger capacity motor for an absolute response monster.
Should be in paint by the end of the year I would say, and Mick has kindly allowed me to re-assemble as much of it as I can at his shop once his bit is done.
  • 3 months later...
  • 3 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
