Hehe nice. I wanted to hug it when I first saw it, then maybe see if I could eat it.
Sadly though - not sure if I am going to ever get a chance to fire it up - looking at another option that could have me abandon the entire build... :ermm:
Is that an RB30 block in the background of Chris's engine room?! Whats he doing! lol
Why would you stop so far into this build? It seems everything has been done properly from the outset, the end result wouldve been just awesome.
Believe me I know how nuts it sounds and it kills me to be doing it.
Problem is I am still a good $25k+ short of rolling up to a start line. If I cut my losses now while most of the parts are still brand new and in their boxes, motor is new etc, it is going to end up costing me the same or less to get into an already fully developed car, built to the rule book, with proven pace, that is also pretty fresh.
Most of the parts will be sold off.
Trying to work out the best thing to do with the shell. Will probably still put it in paint and get it for the most part back together so it's an attractive option for someone wanting to build a caged car. If I can convince the missus that nobody wants it for long enough to get enough cash back together I might end up keeping it. Still very attached and would love to see it back together in my garage.
Anyway - no signed sealed deal done as yet but its in the works.
that black wrinkle paint job on the motor came up mint
did you spray it? if not where did you get it done?
great build thread
The guys from Racepace did it for me. It's just the VHT wrinkle black you get from Repco, Supercheap etc. Looks awesome.
You need to make sure you do it in warm weather and put enough of the stuff on otherwise it can come up a bit weird. Even better if you can get it in a low bake oven - my spray painter showed me a strut brace he did in his oven and it came up really sharp.
  • 1 month later...
Some more progress. Mick was almost finished cleaning up the underneath when I dropped in.
The rails had the usual distortions from years of jacking / hoists, these were pulled back out, cleaned prepped and zinc primered, and for the fronts a 1.5mm plate tacked over the top. Holes will be drilled where the factory ones are to make sure they still drain water correctly. The car had been jacked up from the rail rears as well instead of the diff, so these were pretty ugly but looking perfect again now.
The sill panel seams and roadside tyre change jacking point that was buckled in have also been completely repaired. As of Friday night it should all be sitting in chip coat now!! Going to get a good bake first before it comes back down off the rotisserie just to really make sure everything is dried out, then work on the interior and panels will begin.
I have decided I am still going to get this thing screwed back together properly and then see from there if I can afford to keep it, don't know how I could possibly sell it though.
Some photos:
post-12551-0-52899000-1310942870_thumb.jpgpost-12551-0-29562600-1310942877_thumb.jpgpost-12551-0-64951300-1310942883_thumb.jpgpost-12551-0-72561100-1310942889_thumb.jpgpost-12551-0-96379600-1310942894_thumb.jpgpost-12551-0-07130600-1310942902_thumb.jpgpost-12551-0-91922100-1310942907_thumb.jpgpost-12551-0-29702200-1310942914_thumb.jpg
  • 1 month later...
So what is happening to the bus these days?
It has been put on slow-mo for now.
Bought Snowy's white 34 so getting out and about in that at the moment, entered in Targa High Country and Targa Tas next year so funds are all aimed at that at the moment.
It is however going back together an intended, with the Racepace motor and GT-SS turbos. It will be my tribute to the car that I love so much, and I will get it out to track days where there is minimal risk of damaging it's pristine state!
As much as I would love to drive it in a Targa event, it's kind of a better outcome 1) because it is going to be another one of Mick's works of art once finished that I couldn't bear to scratch, and 2) I can have some freedom with it from rules to do some crazy stuff down the track.. thinking v-cam, maybe some of these newer gen turbos coming through and possibly a larger capacity motor for an absolute response monster.
Should be in paint by the end of the year I would say, and Mick has kindly allowed me to re-assemble as much of it as I can at his shop once his bit is done.
  • 3 months later...
  • 3 months later...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
