Finally got my other project out of the way and starting putting it back together today.
Reunited at long last
New brake booster and master cylinder, have a rebuild kit for the clutch master cyl that I will get on to once I get some circlip pliers.
New engine loom going in
PWR radiator & in-tank oil cooler test fitting. All looking pretty good. Top pins are about 5mm out, and the factory brackets need to be flipped but all looks to sit well. I did have to bend a small lip on the car at the bottom in front of the radiator so that it didn't foul but only a few mm. Aiming to have the fuel tank and most of the wiring back in tomorrow.
Steel steering blush replacement for the rubber one has arrived going in tonight.
Also need to get a replacement dust cover for the input to the rack. Literally just touched it when cleaning the subframe and it fell apart. Apparently there is a toyota rubber one that is the same size and fits well.sristeerspacer.jpg
How the fk do you get the time to do this? Please let me know if you have managed to clone yourself!
Ha I wish. Yeah just slowly chip away at it. Good to have a space where it can just sit and you can put time in where you can.
  • 3 weeks later...
Hi Paul
I am most impressed with the level of detail you have gone to. I am just embarking on a R32 build myself using the good fellows at Racepace so I am feeling rather inspired now after reading all the posts on this thread. Good luck with finishing it mate. I will start my own build thread I think. Ev.
Solid steering bush in, also grabbed the dust boot of my spare 34 rack - a little different but its rubber and fits up pretty well. Will do the trick seeing it wont be driven on the road.
Hi Paul
Thanks Evan. Is your car already at Racepace? Was there on Thursday and there was a white 32 that looks like the one in your sig - a nice example! Get on to the build thread for sure.
Yes very tough! Should be even meaner once all the junk is removed from inside. Cage should look good too. Got to decide how that will look as well. I might make a hybrid of yours or Duncan's perhaps..
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
