All gone I unfortunately. All i have is a TD05-18G laying around
What were the Kinugawa like?
I can get a T67-25G with trust housing from them.
The brand whore in me says stay Trust.
But it's over double the price.
Not keen on getting the L2 modified.
Will either swap for a Trust T67 or keep I for a rainy day.
My Kando is new so cant really comment. Having ran a TD06-20G 8cm and T67-10cm in my RB25 i petsonally suggest you get a 10cm housing fot your L2. On E85 eill make a fat 310rwkws...made for a way faster street car then the T67. The one PI day i did with the T67 it was a good thing good  mud and strong top...but on the street the 20G was waaaaay punchier and pulled way harder in tbe mid to top...just lacked that extra 50rwks after 6,500rpm that the T67 happily saw up top to 8,000rpm
That's my concern. Too small for the 2.5L.
The L2 with 8cm rear should make 315 according to the trust book.
Compressor side is the issue. Cropped wheel and all.
45 degree curve and out of puff very early I believe is what to expect.
Perhaps just go with it and see what it does on the dyno?
  • 4 weeks later...
  • 1 month later...
  • 6 months later...
On 11/13/2018 at 9:28 AM, Roy said:
So...this will keep me honest...
Thanks always to Racepace for being able to make a bunch of mismatched parts cobbled together work so well
That’s some nice streetable horses!
So 2 days at Bathurst didnt go to plan. Slapped enough stuff together to do only 1 lap. Fuel filler tank kept spewing fuel meaning meatball flags. Then had a few other small similar things go astray...and ultimately fixed a few things on the fly that called into question  othet things that need a dyno run to work through so only did a lap at gate pressure
Running twin GT2860-5s
T
So looking back a week later now I feel frustrated. The first and only lap was a rather leisurely lap and not bad at 2:42 all things considered.
Wish I could have gotten another 3-5 laps as I think I would have gotten it down into the low 30s or high 20s rather quickly. After that its going to take a load of laps to get anywhere near the limit....but not even worried about that. Its definitely a place where you need to treat it like a tarmac rally and appreciate that a pinched brake may mean a horrible table top ride back to the pits :(
Anyway...over the next few weekends will need to fix the stoooopid filler neck. Fuel tanks check/roll over valve and stupid radiator shroud that decided to crack and meet the viscous fan. Stooopid old cars and meatball flags! ?
  • Like 2
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
