Not a real lot of major work has been happening with Cheryl lately,,,just a lot of jobs that need doing before the interiors finished.
I've almost decided on wheels though,,,I'm thinking R32 GTR V-spec's. If they are good enough for a 4wd then they are good enough for me. I have a set here I'm minding so I fit them up and see what they look like.
I've pulled the pin on running at World Time Attack,,,I need a speed fix sooner so the Radical is going to get some work done on her and I'll be going hillclimbing again.
Seems there's no rush though as my tyres are still on the way from pommy land,,,Avon stuffed up the order apparently.
Early on in this thread someone thought I was crazy not spending my budget on the Radical,,,check these lap times out of Wakefield last weekend. Mines a 2000 Prosport,,,not the latest SR3. I'd be about a 1.01.
Qual:-
http://www.natsoft.com.au/cgi-bin/results.cgi?17/04/2011.WAKE.Q3
Race 1:-
http://www.natsoft.com.au/cgi-bin/results.cgi?17/04/2011.WAKE.R3
Race 2:-
http://www.natsoft.com.au/cgi-bin/results.cgi?17/04/2011.WAKE.R11
Race 3:-
http://www.natsoft.com.au/cgi-bin/results.cgi?17/04/2011.WAKE.R19
Cheers
Neil.
Oh Ya,,,mid field,,,wouldn't that be awsome great fun. Think I'd last 3 meeting tops before getting a second job to buy one of these.
http://www.my105.com/ListingDetails/tabid/65/p/3/k/West/id/1348/Default.aspx
http://www.westracecars.com.au/leasebuy/used-race-cars
which would be great for maybe 2 seasons and I'd still be packing shelves at Woolies every night.
But on a different note,,,I've changed my mind on wheels,,,I thought I was only allowed to go up an inch both ways from standard which would be 17 x 7.5 but a re-read of the rules see's me able to run 2 inches both ways so I'm now looking for 18 x 8.5.
After much searching I finally bought these Sparco belts. Not only because the dollar is great but you just can't buy them here at the moment.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=200451877096&ssPageName=STRK:MEWAX:IT
Still waiting on gauges to come out of England,,,they should be here in a week or two.
Thats it for now.
Cheers
Neil.
Neil - Shame you cant run 9" wide wheels, 33 GTR rims wouldve been the go.
There are plenty of good light 8.5" wide wheels around...just not 2nd hand
Also...if you are looking for bits and pieces JEGS in the US have some good sales on atm
Yea I hear what you are saying Zebra-man but it's all good,,,given the power output I'm restricted to I think the 18's will be great. I'm just about finished with buying out of the states,,,I only need a dry sump pump now.
I received my gauges today,,,I must say stack make great gear,,,everything is included,,,funny the pressure senders are autometer and all connectors are water proof.
I bought oil and water temp,,,oil and fuel pressure. That should do me nicely.
Cheers
Neil.
Two and a half pairs actually.
I seem to remember always thinking Kel's 350z wheels were as heavy as.
Troy weigh one for me will you.
Cheers
Neil.
they arent too bad but lots more than aftermarket jap rims - and the older touring 18's like im using are non staggered even offset
some specs available here :
http://www.350z-tech.com/wiki/index.php/Wheel_Specifications
what about evo wheels? pretty sure they are 18x8, you would just need a spacer to fix the homo offset they run
Oh wash your mouth out with soap Ben,,,that sounds absolutely disgusting.
Here's something that has turned out great,,,nothing to do with the car but it makes life in the garage easier. Rather cold tonight. $500 bucks well spent.
I've seen this conversion done before,,,using rear shock mounts on the front,,,pretty easy really.
I removed the larger factory studs out of my standard front struts top hats and machined the heads down to fit in the HKS mounts using an electric drill as a lathe and a file in the vice. Next I drill out the holes with a 10.5mm drill and pressed the studs in using my vice. Worked a treat.
Before
After
Rather happy with my nights work.
Cheers
Neil.
yup... time to get that tatoo saying "i like men"
Got the number bitches of said tatoo shop.
I like my apple juice and I like it sweet.
I did heaps of very stupid little un-interesting jobs on the weekend,,,but this was a bit of fun. I've never played with carbon fibre before and after some hours of working out where I wanted my gauges,,,seems like I need to buy one more. Volts or Exhaust temp,,,I can't decide,,,but I did leave some room for switches and idiot lights.
Cheers
Neil.
That is what I need to mount my gauges on - please text me where you sourced the carbon fibre sheet from.
How are you going with wheel selection?
I have a few sets for my car but 18 x 8 with a 30 offset seems to provide good clearance and fills the R33 guards well.
Good old Jap wheels are a lot lighter and stronger that some of the new options that are going around and still affordable. You also have to think about spares as well so multiple sets would be in order. I have stuck with the old favourites of SSR, Enkie, Buddy Club, Nismo and OZ Racing for my collection in keeping with the R33 becoming a classic and look better with rims from the same era.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
