i'll find a black pair and chop them on and repost
was thinking black but that thread with the jap stageas at the track had a yellow s2 with white wheels and it looked good
Just painted my front headlights!
Chris.
Very nice indeed :3some:
I know a couple of people who want to do that pretty badly :)
Replaced the power steering fluid with Nulon 100% Synthetic ATF, replaced the lower weather shields on the front doors (finally!), gave it a clean yesterday.
Chris.
love it they look fkn great!
Just brought mine back from the car wash...
Oh, and I changed one of the map lights - both were still working, but one was really dim.
Nick stop going all out with ur car dude, or soon ull have to enter autosalon....
i,ve not long had mine, figure i'll wait for things like the turbo to go before spending up on them but it came with r33 four pots on the front, i tinted the taillights and removed the nissan and stagea badges off the rear, got a gps traker alarm with remote shutoff and a blitz cat back exhaust and high flow cat which aren't installed due to the lack of a dump pipe but i's coming lol :)
Yesterday I cleaned the engine bay and gave it a good wash. Today I'm gonna hit it with Mothers Clay Bar and then Meguirs Gold Class Wax. Should look awesome :(
Also, just bought an Innovate wideband O2 sensor that should arrive tomorrow. I'm gonna wire it in to my Vipec ECU and leave it in the car pernamently. Can't wait to play the tune :( Just gonna try and lean out the low-load everyday driving parts in the search of better economy.
just went under mine on the hoist with a torch and a bore scope, and found a few loose fittings, a stuffed tranfer case seal, a loose tailshaft, a leaking coolant seal on the front turbo and a loose front cradle.
Hopefully this afternoon I'll be saying I picked it up with all issues sorted! :(
i finally made a heat shield for my pod
went to foamland (dodgey tassie version of clark rubber)
bought 0.5mx~1.0m of foam with a foil backing for $13.75
got the stanley knife out and started hacking away
ended up with about a .4x.5 m piece left
doesn't look pretty but seals around all the pipes and things well and looks like this:
i'll add a cold air feed in when i get a chance/can be bothered
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
