I fitted a Boost gauge to my stag at work tonight. drove home, standard solenoid standard turbo - 10 psi. strange. now i just gotta try and work out why it's running so much boost, either a faulty gauge or it has an rb20det boost solenoid fitted.
i grounded out the solenoid via a switch so i can run low or high boost which happens to be about 5-7 for low and 10 for high
i also have an electronic boost gauge and would happily swap it for a normal one
where did you guys take the boost reference from? mine is plugged into the drivers side rear of the intake manifold right next to the brake booster piping. might try putting a t- piece into the boost sensor hose and see if it reads different.
very surprised it didn't fit - every skyline brake bit I've put on mine bolted straight on....I've run gtr front and rear brakes on it now?
what was the problem, did the adapter hit on something? Either way Im sure UAS will refund.
Hi guys with slight mod they do fit . But once on the spacing is 11mm off . Even with a spacer the disc wont fit under the caliper without fouling .
did an oil and filter change today
guld western s6000 sougi - awesome stuff
car runs sooooo smooth
$68 and its the same spec as motul 300v or royal purple (shits all over penrite, nulon, castrol etc)
You are running the skyline disc to suit that kit not the stag one right? They need to be changed as a pair
Spent 8-9 hours at custom exhaust shop standing around and helping out getting new front pipe made, cut and reweld my new exhaust which was bent in 3 places and new/modify intercooler piping to suit new turbo and front facing inlet plenum
I am using a 324mm skyline gtr disc & sumitomo calipers off a skyline . So i think am using right parts but any advice would be appreciated.
Well today I have finally finished the Front Facing Plenum fit out complete with a FMIC. It has been quite a long project
as being 50ks from suppliers is a bit of a drag. Every time you need a bit it is a 100k round trip.
Anyway I am happy with the way it has all turned out. I will have pics of it next week when we do a road test. My boys are off to Eastern Creek tomorrow in the 25G.
Spent an hour last night relocating (slightly) and refitting the handbrake assembly, for my modified manual console surround (grafted the Stagea auto surround and an R34 manual surround together). It all fits and now I just need to improve it cosmetically. Got some leather boots for the stick and handbrake with red stitching coming from ebay, and I'm also fibreglass puttying up the console to sand it back to a smooth finish.
:ermm:
:down:
Pics please!
Well I thought I would kill a couple of birds with one stone. I needed a new GPS and car kit.....easy answer Garmin 1490T(great unit)....but I also wanted an Greddy Infometer.
It had been mentioned to me that Garmin will be coming out with an OBDII port dongle....http://www.ja-gps.com.au/Garmin/ecoroute-hd/
Anyway that day arrived yesterday and as I received the much awaited package and unwrapped with excitement then hooked it up. I soon came to the conclusion the ecoroute-hd didn't work. F#$KING M35's!!!!!!
I did decide to test it on some other cars though......much to my joy :down: (not to my mates)....it doesn't work on a V6 commodore either....and I cannot even find the OBDII port on another mates Mitsashitty 380.
Pity this would have been awesome for the price
Plenum in. Started the Stag. Took a few turns to get the fuel up. Ran like a dream up to 2500, then total misfire. WTF.
Checked all connections and found AFM plug not in socket properly. Clicked in and PRESTO. Music to my ears.
Get the wheels on then off for a drive.
Polished up the brembos today and they are in awesome nick! no marks at all :D very happy.
All the braided lines (approved) are here, just waiting on the rear caliper bolts to come through Nissan from Japan.
Clean pic below!
Edited by bbenny
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
