I fitted a Boost gauge to my stag at work tonight. drove home, standard solenoid standard turbo - 10 psi. strange. now i just gotta try and work out why it's running so much boost, either a faulty gauge or it has an rb20det boost solenoid fitted.
i grounded out the solenoid via a switch so i can run low or high boost which happens to be about 5-7 for low and 10 for high
i also have an electronic boost gauge and would happily swap it for a normal one
where did you guys take the boost reference from? mine is plugged into the drivers side rear of the intake manifold right next to the brake booster piping. might try putting a t- piece into the boost sensor hose and see if it reads different.
very surprised it didn't fit - every skyline brake bit I've put on mine bolted straight on....I've run gtr front and rear brakes on it now?
what was the problem, did the adapter hit on something? Either way Im sure UAS will refund.
Hi guys with slight mod they do fit . But once on the spacing is 11mm off . Even with a spacer the disc wont fit under the caliper without fouling .
did an oil and filter change today
guld western s6000 sougi - awesome stuff
car runs sooooo smooth
$68 and its the same spec as motul 300v or royal purple (shits all over penrite, nulon, castrol etc)
You are running the skyline disc to suit that kit not the stag one right? They need to be changed as a pair
Spent 8-9 hours at custom exhaust shop standing around and helping out getting new front pipe made, cut and reweld my new exhaust which was bent in 3 places and new/modify intercooler piping to suit new turbo and front facing inlet plenum
I am using a 324mm skyline gtr disc & sumitomo calipers off a skyline . So i think am using right parts but any advice would be appreciated.
Well today I have finally finished the Front Facing Plenum fit out complete with a FMIC. It has been quite a long project
as being 50ks from suppliers is a bit of a drag. Every time you need a bit it is a 100k round trip.
Anyway I am happy with the way it has all turned out. I will have pics of it next week when we do a road test. My boys are off to Eastern Creek tomorrow in the 25G.
Spent an hour last night relocating (slightly) and refitting the handbrake assembly, for my modified manual console surround (grafted the Stagea auto surround and an R34 manual surround together). It all fits and now I just need to improve it cosmetically. Got some leather boots for the stick and handbrake with red stitching coming from ebay, and I'm also fibreglass puttying up the console to sand it back to a smooth finish.
:ermm:
:down:
Pics please!
Well I thought I would kill a couple of birds with one stone. I needed a new GPS and car kit.....easy answer Garmin 1490T(great unit)....but I also wanted an Greddy Infometer.
It had been mentioned to me that Garmin will be coming out with an OBDII port dongle....http://www.ja-gps.com.au/Garmin/ecoroute-hd/
Anyway that day arrived yesterday and as I received the much awaited package and unwrapped with excitement then hooked it up. I soon came to the conclusion the ecoroute-hd didn't work. F#$KING M35's!!!!!!
I did decide to test it on some other cars though......much to my joy :down: (not to my mates)....it doesn't work on a V6 commodore either....and I cannot even find the OBDII port on another mates Mitsashitty 380.
Pity this would have been awesome for the price
Plenum in. Started the Stag. Took a few turns to get the fuel up. Ran like a dream up to 2500, then total misfire. WTF.
Checked all connections and found AFM plug not in socket properly. Clicked in and PRESTO. Music to my ears.
Get the wheels on then off for a drive.
Polished up the brembos today and they are in awesome nick! no marks at all :D very happy.
All the braided lines (approved) are here, just waiting on the rear caliper bolts to come through Nissan from Japan.
Clean pic below!
Edited by bbenny
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
