Picked up the stag after new plenum install.
Sex!
Just ran a rag over it, so she's not detailed properly :)
Is that my throttle cable???????????????????
Why 66, yes it is! And its thanks to you I have the stag now :))
Incidently are the cam covers polished or chromed? My Gready look alike is chromed so i want the covers to look the same.
thanks mate, havent seen u for a while, and im on 2 weeks hols atm too so it will be a little while...though maybe not looking
forward to the roughness of annangrove road :)
Yeh it has been a while, Annangrove road is shocking at the moment i have been leaving the skyline at home most days and using the daily hack, hope they fix it soon.
badly when it rains down that road it looks like a mine field....
hi flow turbo and WB o2 sensor is in, max tp limit so no more fuel cut, pulled some fuel out, added a few degrees of timing and now its standing up when floored. Damn AFM is maxing out now though, will put my z32 one on tomorrow.
Also noticed when i took the standard turbo off that the impellor is all chipped, explains the noise when it was on full boost, (i was chasing a boost leak, it sounded like air squeeling). Looks like it wont be going back on the r32.
Whilst loading a case of beer into my garage beer fridge, accidentally dropped one on the floor. Bottle hits the ground, smashes, then to add insult to spilt beer, the broken end with the cap still attached, bounces 5 feet, hits the door of the Stag and put 3 little scratches on it!
F##k this for a game of soldiers, going to drink a few of his mates, that'll learn 'em...
found out why it whines on high boost :worship:
getting the turbo off was not the most enjoyable job tho
will fit the new gasket tmrw and bolt the 3inch dump up
also, lolz at the stock dump pipe, i'm surprised that the wastegate can even open
i also have a sneaking suspicion that the rest of my exhaust is 3.5 inch cos the front pipe on my car is a bit bigger that the 3 inch dump/front pipe i have and it necks down just before the dump->front flange
So after having my replacement engine in for a few weeks with a hi-flow on it, it is now back to a rebuilt std turbo, (my old one) with a ceramic impeller. The difference is HUGE. The hi-flow didn't come on until 3200 rpm. It was at max boost at about 3700rpm. The newly rebuilt std turbo is on boost even lower than it was before the engine was replaced. It starts coming on a 2200 rpm and pulls hard to about 6000. The car now has a Nistune and will be tuned before the weekend. The hi-flow was not for me, that's for sure. It was slower than my wife's Maxima, until it got to about 60kph, then it was doing over 100 kph before you knew it..... crazy as far as I am concerned.
I'll post up the dyno sheet after it is done.
Edited by Appealing
Replaced the plugs in my Stag and replaced the coilpacks too. Checked the CAS timing and reset the ECU while I was at it. :D
Also chasing why my brakes makes this loudish acoustics noise when its moving backwards (rolling back or reversing). Makes no noise moving forward. Got new pads and bedded them in on the track. They were fine up until I had to reverse out of my driveway for the first time with them. NOTHING is rubbing the rotors except the pads.
Mine does the same thing.
Jetwreck gave me his old r32 disks complaining bitterly about the squeal they had but I must have put them in backwards. ;)
Should have tried swapping them Craig...
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
