http://www.turbo-kits.com
quote me $1429 + postage for a GTX3071R with a 0.78A/R split pulse turbine housing. Send them an email to get a quote.
this is the one to watch.... IMHO the only turbo for an unopened RB25 that might be as good as (or possibly better) than the HKS 2835
Okay... Now I'm confused... Got me a r34 gtt and don't really want to forge my engine so I want a 280-300kw 'safe tune', doesn't sound safe but surprisingly it does well amongst most... and obviously 350kw for the odd car which I cannot rape. Now would the gtx3076 be the go for that? A 3582 would give me a safe tune on 300 or less however I'd assume much more lag... but future aspirations of good old fashion power rape... Or do I go for a 3071 but what optimistic power figure would I get on a rb25? Only thing pushing me away is the less lag of the 3071 but the 3076 will have more power which my engine may die from and the 3582 can run safely with much lag and possible engine detonation when we get trigger happy on our little boost controllers :-(
Lots Of Love,
Purple skyline with a ridiculous white front-mount.
Isn't the GT3082 basically a GT35?
If so then how does the GTX3076 come on later and make ever so slightly less power? Just doesn't make sense.
or is it the transient response which the dyno does not show where it has the improvement over it?
Lots Of Love,
A 3582 will not necessarily give you a 'safer' 300rwkw than a smaller and capable turbo would. Both a 3071 and a 3076 are capable of 280-300rwkw given the rest of the setup.
Power is power, theres a certain level of power any given motor can produce before it starts to pull itself appart. Above the 280 mark is going to start impacting the longetivity of the RB25 as mentioned.
Simply look at what turbo is capable of what power level in the RB25 dyno thread and decide from there. The garretts are known to make the numbers without too much stress on the motor (charge temps etc). High flows are still under scrutiny in this respect. An easy and good feeling 280rwkw is generally acheived from a 3076R .82IW.
Its simple.
If you can afford the rebuild, chase over 280rwkw.
If you can't, then don't.
The man speaks the truth!
Nah, still a gt30 turbine. You would assume transient response would be better with the smaller wheel but it should be reflected to a degree in the dyno as it should spin up faster initially and the effect compounds.
The theme i am seeing here is that the gtx wheel has a comp map that is comparable to the next size up gt wheel, the gtx turbos response is comparable to a turbo with the next size up gt comp wheel and same turbine.
Have garrett wasted a heap of development money making a small wheel that ultimately performs the same as an old gt wheel or are we just not seeing the right results?
From left field and a theory about this result, a gt3082 is too much compressor for a gt30 turbine, you'd probably see a better result for both response and power from a gt3582. Does this then carry through that ideally the gtx76mm compressor should be matched with a gt35 turbine and in that scenario we'd see better results?
you aren't going to chase 350rwkw+ until you have spent another 5k so i would say go for a GTX3071 .78 IW as it will be the most lag free and fun way to get to ~280rwkw and then IF you decide to rebuild, sell the turbo then and by a 35XX
+1 i think he is going off the whole less psi is good train of thought...
remember psi = pounds per square inch so that for example, 15 psi from a 35XX will actually be cramming around the same amount of air into the motor as say 19 from a 30XX
Without driving the car it is hard to judge the transient response of the GTX turbo. The GTX3071 is still the one I want to see more results on a RB25.
Slight correction there is a 0.63, 0.82 and 1.06 IW (in the Garret range) the 0.78 is a ext twin scroll housing.
I believe yes. I'd like to see a GTX3576R
OK I am even more disappointed with the GTX3076R than I thought I would be. I had said before anyone tried results than I suspected it was going to be more or less like an expensive GT3082R, but it actually looks laggier than I expected it would be.
To be honest I am starting to doubt that the GTX3071R will be as awesome as I thought it would be. Now it looks like its probably going to end up with (baring in mind there is pretty much no noticeable spool difference between a GT3071R and a GT3076R) a GT3076R which makes slightly more power with slightly more lag. Hardly worth it.
My prediction - when more Borg Warner EFR results come in, the GTX turbos are going to be made to look stupid.
Not convinced here. The GTX 76mm compressor appears laggier than the GT 82mm compressor, which has imho a better overall pumping efficiency. Its basically got nothing on it, going from results I've seen so far. The GTX 76mm so far seems like an expensive waste of space to me.
Why bother with a GTX3576R when there is a perfectly capable GT3582R which appears like it'll have no more lag, at least worth mentioning?
Agreed. The one independent result that's out there already looks promising.
  • Like 1
Yeah. Garrett GTX looks like it does next to nothing over the old turbo. Borg W EFR seems to be offering better spool. Still waiting to see more results but that lighter turbine wheel seems to be good.
Results:
SR20DET fitted with a GTX3076 .82 tuned with BP98 Fuel - 408hp @ 1.5bar
Well the GTX3076r looks to be identical to the GT3082r ! (both turbos were using the same rear housing)
Below is the Power and torque readings @ 1.5bar
The boost actually starts off at 1.4bar and creeps to 1.5bar toward redline
Thick line is Hi boost setting, Thin line Lo boost setting
Interesting..
A comparison for you:
GTX (above) VS GT 3076 52 trim twin scroll .78 (below) on SR20 on same dyno at around same boost.
4000rpm 100hp (GTX) vs 240hp twin scroll GT
6350rpm 390hp (GTX) vs 388hp twin scroll GT
Peak 408hp (GTX) vs 388 hp twin scroll GT
Twin scroll...virtually more torque everywhere and hgher peak
Edited by juggernaut1
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
