I've recently bought a GTX3076 .82/AR twin scroll twin wastegate setup, for a built SR20 though. Will be keen to see the results.
I want to do a comparison with the GT3076 that another one of our customers has, as well in the same setup and compare response and hp.
I cannot say I have heard a lot of good reviews, but I believe in giving things a go!
if the panel shop painting my car would hurry the "f" up i might get some sort of results in this life time. 5months still waiting.
/ end rant
Edited by BMYHOE
  • 1 month later...
thoughts on a GTX3071 with .63 external 44m gate on e85 strapped to RB25 with all supporting mods and poncams? much of a muchness between the gtx and normal 3071?currently running a 52t, 3076 .82 IW and not happy with the 'punch' out of corners. its always that 500 or so rpm behind the 8 ball
I think you would net better results if you just delete the GTX3071 part... Stick with your current CHRA an use the money on a 6boost then the manifold and gate.
You should get what you want but then you will probably want more thereafter.
Thats quite interesting, do you have dyno plots or more specific information on its behaviour on track? I had a .82a/r internally gated 56t GT3076R and that was brilliant on the track, any time you did have lag it was typically a low enough speed corner that you wouldn't want any more power anyway as you'd potentially be doing skids or understeering... makes me wonder if there is a problem somewhere with your "combination". Given that mine was no laggier than a stock turbo STI/EVO, which are basically factory made to be great for track - something that should be more responsive should be a dream!
Before doing something rash (unless you've already been convincingly down this path) I'd look into making sure you've got your current setup humming as well as you could, I'm not at all convinced you should be able to get a lot more response without going to something close to stock.
the comparo of the compressor maps of the 2860rs and 2863r looks promissing:
http://www.atpturbo....se110101-1.html
yeah, not that interested.
Maybe a small increase in power from the gt to the gtx but you are still limited by the turbine/housing combo as you are with 2871's.
^^x2
i do, there in the rb25 thread. and recently fitted poncams and the big can actuator.
dont get me wrong the car is fun, full boost a bit before 4k and pulls hard all the way. whats making me want to make some changes is a friend who had the exact same bolt ons + cams as myself car is completely different to mine.The only difference is he went the 56t .63 external and 44mm tial. while they make the same power on the same boost, and on a dyno his response is probably 300ish rpm better (could just be the housing), their 2 very different cars in the way the power is delivered. driving behind him coming out of corners or even straight line stuff he'll always pull that couple of car lengths, and if you know Mallala well the track is very start/stop. Weve swapped cars several times and the rear housing and gate option is the only relevant difference.
my first issue to rectify is to go back to the MTQ 1 bar actuator, which seemed to drive nicer than the big can. the other option is to just change rear housings to the .63 and go external gate.
As i said, im happy with it, but there is definantly room for improvement somewhere
I think you have your answer in that post man.. .63 up and get a gate.
I wouldnt change the turbo but.
Wanted to get some feedback.. R33 GTR motor, freshly built, stock compression, tomei cams, sprockets, coilpacks, + all standard bolt on performance goodies, will run a GTX3582R with .63 housing.. any power ideas on power I can expect to see?
I also have an .82 housing i will turn the car on as well so i can switch to it if I like it better.. however the idea is less boost lag.. keep in mind this motor is in an s13 chassis which weights some 2800lbs.
tks!
.63 is going to be very tight on a GTX35, to run that turbo you will want a .82
The other issue is your turbo is far exceeding your stock bottom ends capability, that setup should be good for over 400rwkw but the stock internals will generally start to let go at that mark (400rwkw about 530whp).
If y ou dont own that turbo yet you may want to consider another option unless you want to built the entire motor. I will make point that you have used the words 'less lag' and you have picked a fairly laggy turbo (running a tight housing is a bandaid fix and will just cost you power). You will be better off with a smaller turbo if you want more response (and not need to build a motor).
AFAIK also the regular GT3582R is looking more favourable than a GTX3582 or GTX3076, something you may want to review before you buy (GT series wont need as much boost to shine).
I beleive the article disco posted the other day explained it very well..
The GTX turbos are aimed at newer engines that are running 16psi from factory and so require higher boost levels to push more power...16psi was alot for a skyline in the day to make decnt power..
i suppose for newer engines being more efficient with better flow characteristics, losing the bit of response in a turbo isnt a big deal as the newer engnes can compensate for this.. But having the ability to flow well at 30 psi is more important....
So yeah maybe your skyline is better off with the old tech turbos that were designed for the engines of its time :unsure:
why do they require more boost...EVO's are a classic example, 1.6BAR standard, but put a gt3037 on there and will make the same power on 10psi.
The article was just Garrett PR trying to create a market for them which doesnt truly exist. the GTX turbos haven't set the world on fire, and I believe Garrett have spent <5 mins developing these Billet wheels simply because they are the current Fad in turbo tech.
If they truly wanted a new super high performance turbo they would have been done from scratch, ala BW EFR
while i agree about the PR campaign and that the new garrets are nothing revolutionary, just a case of malibu stacey with a new hat...Im not convinced there is no market for them
I beleive some new cars, (in particular the new mazda range comes to mind) are loving them..However I will try back this up with facts before I make a stand ;)
Oh people are buying them, But I'll stick to the old GT stuff if I go garrett, I'm just not convinced they are worth the extra coin (especially when I can get a FP modded one cheaper). But time till tell 12-18 months from now with more results that paint a clearer picture on how much extra they make etc
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
