Recieved a box today containing my R33 calipers!
Got all the lines, shims and clips, and as a bonus what appear to be a virtually brand new set of brake pads :thumbsup:
Now for some offset brackets & bigger rotors.
There not r33 gtr brembo's are they?
No mate, sadly my finances don't run to Brembo's unfortunately, but I think the R33GTSt calipers teamed with this;
http://www.conceptzp...40203.166.28.81
I should have more than enough brake power.:thumbsup:
agreed, the brembos are about 10% more braking at 100% more cost. no worth it. 32 gtr/33 gtst are excellent for the price
Interested to hear how you get on with these brackets. I have tried several on my C34 without being able to fit them (very different from Skylines) although I see you have an M35 - lets hope they are the same as 350Z.
well this weekends pretty big for me now..
changed the spark plugs, to find that when i bought the car they had put iridiums in already :D SSV did a good compliance!
phenolic runner spacer.
suction pipe thats scotts making up.
then injectors are going in, and Cihan the tuner is coming around on monday to install my emanage, and dump the stock tune on it with bigger injectors..
just untill another couple of weeks before i can tune the bugger..
Craig- guess we are gonna try beat eachother now hahah
So are you tuning next weekend as well then? That's OK bud......I will enjoy the tear's I'll be seeing on your face when I blow your result's to the weed's...lol!
Yeh they will be fine...basically the same as what I am running atm!
Yeah, I had an R32 GTR setup on my r31, and that kicked arse, so I just wanted the bigger rotors to counteract the additional weight.
^ what the bolt size on those? wouldn't they have both holes drilled for the smaller size bolts?
I get so confused...:wacko:
Yep, but I'll be drilling out the M12 hub bolt holes & retapping for the M14 bolts from the original M35 calipers.
Alternatively, you could just use the bolts that come with the kit and use a sleeve inside the hub bores to take up the gap. Not too keen to do that with the additional bracket though.
Edited by Daleo
I dunno yet man. Might just wait a fortnight coz i still gotta get the boost sensor. U probably will with the bigger turbo I seriously don't know what to expect anymore. Hopefully more than 250 on e85
Lol....just toying with yah...250 is the figure I am after with normal unleaded.
Dale, where are you getting the adapters for the bigger rotors from?
I keep looking at the ones on ebay in the US for the S14 and the Z32 and wondering if these will work?
Do you have any idea if these will fit our car?
Cheers
Andy
Disassembled my 'stock' seats to remove the airbag sensors today, drivers side had the plug snipped from and when I went to directly wire it in I noticed the wiring on the plugs looked a little odd.. Id say the drivers side has the 2.2 OHM resistor between the wires (couldnt take it apart - the unit was covered in heat shrink and was 'boxy' so I guess they heat shrunk around a small plastic box which contains the resistor connecting the two plugs)! But I was able to plug the passenger side back in, so Ive secured that to the seat and reset the airbag light. Now I get to play the waiting game to see if the blinky light returns :domokun:
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
