I dropped and changed the oil in both diff's
the oil that came out was putrid and like it had turned to water. glad i did it.
also got scotty to make me up a new "pre throttle body" IC pipe (the one with the BOV attached to it.) Have a look. gonna get some 3m sticky heat shield and cover it up. should look good
Easy to drop the oil in the diffs?
Me thinks a Tutorial is a good idea :D
good idea. might write one up on the m35info forum if the mod's want?
took me 20 minutes each diff + the time it would take to take the tray(rock deflector thing) off the front
you need a 1mm Allen key 3 quarts of diff fluid - should take two and abit.
same as servicing the transfer case.. drain with bottom allen key bolt, close up. fill with top allen key bolt until it overflows. pretty simple honestly.
dont know if u notice a difference in drive, but gives you piece of mind knowing you've done it.
I think if you come from S.Africa, its called a Ellen key.... (saw it written on a S.Africans toolbox - lol)
Anyways Going to strip, clean, and re-set the Throttle body this weekend. Any tips?
I got the reset idle air volume instructions etc etc... anything else i should know, what to touch/ what not to touch?
also interested. i cleaned the visible part last night. now warm idle is 750ish RPM
oops.
can it be reset?
Depends. Not on my original one it couldn't.... unless Iain has somehow managed it.
I think I may have stretched whatever is in there because my warm idle was just over 1100rpm (cold was around the 1600rpm mark)
Edited by iamhe77
650 +/- 50rpm is factory spec, so 750 shouldn't be an issue.
Mine idles 550-650 (500 when hot). No issues at all.
Guess it just comes down to how comfortable you are with it.
yeh. if i come accross a second hand one, i'l grab it and fix it. but i think it will be on the 'when i can be bothered' list
why not clean and re-set the idle...?
Nothing to stretch in there - its only cogs/motors/sensors afaik
mine is about 750 at the moment in N or P, about 700 in D.
Did the other shopping trolly (that has done 175k Kms) today, cleaned TB and MAF, good result -idles much smoother now :thumbsup:
Cam had one that wouldn't set the idle after cleaning. Mine is the same. I don't mind an 800rev idle in drive though.
Mine may not set the idle any more due to the engine light being on and the ecu in fault. It will drop the revs after the learn but the next time I start it the idle has raised again.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
