OK so I got my new grill today....sprayed it up and fitted it.
Thoughts!!
In my old age I am starting to LUV black. :rofl: :rofl:
Some gentleman ran into the side of the N/A today. Not too bad, about $1500. We were stopped at a light and the dude just drove into the rear P/S bar.
Thats fairly impressive, you managed to take two photo, minutes apart & from an identical position, with your finger over the lens both times :P
Looks good !
P.S. It's the case on my Iphone4 not my finger's leaving the mark...lol!
Edited by Jetwreck
The new one, probably because its a bit similar to mine :whistling:
ahh damn! glad youre ok mate
i think they need to do annual testing of older drivers from 70 now.
i got taken out by a 74yo lady who said she had a green arrow to turn. except she wasnt at that intersection.
I've been saying that for over a decade. If they can clamp down on p-platers driving turbo cars, how about annual testing for those idiot elderly drivers!
I see elderly people making big traffic blunders all the time. At least twice a year we get them driving the wrong way down the freeway/expressway.
:down:
The conditions today were clear, dry roads, total visibility ... yet he didn't see me :blink: Time to give it up gramps.
Just put a 32gtr blow off valve on the M35. fits nicely, sounds better...
just need to find a radiator hose i can stick in to make it plumb back again..
i dont really know what this is going to achieve however. i was bored and had the car apart in the garage
Bought one: http://www.northshoreprestige.com.au/view.php/used_cars/2001_Nissan_Stagea_250tRS_FOUR_White_5_Speed_Automatic_Wagon/4470190/
Does that count? :P
Plan at the moment is major service first and foremost.
Then need to decide next move. Intake runner spacer, exhaust, coilovers or front mount probably. Still undecided.
Bought one: http://www.northshor..._Wagon/4470190/
Does that count? :P
Yeah, I reckon that counts :thumbsup: .
I love what happens when you click on the link. It says "Sorry an inventory issue has ocurred". Interesting way of saying the car has been sold.
blacked out the headlights today, had to take the left one out to fix the seal as i saw condensation in there other day.. and thought while im at it may as well get the blacking out of the way.. I love the look..
did the oil and filter aswell.. once i put it all back together my engine check light came on.. anyone have any thoughts as of why??
im thinking when i moved the airbox and bumped the A/F meter just the usual amount when moving nothing violent..
it shoudnt be to do with the lights right??
anyways enough work for today i will run diagnostics tomoro.. see what i find..
car runs fine no different at all..
anyway pics
sorry for the bad pics its the iphone 4 in a carpark... never a good combo!!
Nah, won't have anything to do with the lights.
Did you have the car running with the AFM unplugged? Doing so always brings up the CEL.
If so, it will go away after a little while.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
