This is what I'm aiming for, what's your setup?
Autech 260RS
Stock bottom end
Stock FPR
R34 GTR turbos < Terry's old turbos :whistling:
Nismo 555cc injectors,
Walbro fuel pump
Power FC
AVCR
Z32s
Greddy suction kit and cold air box with factory snorkel
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Yoshida Garage custom ported head and port matched exhaust manifolds
Greddy extended split dumps and front pipe
Fujitsubo Cat back
Gutted cat
N1 oil and water pumps
Greddy oil cooler kit
Turbosmart BOVs
312.5kW at 16.5 psi
272kW at 13 psi
yep, the jaycar kit, works perfectly. Just tapped the speedo wire at the dash and hid the box up behind the hazard light switch. It's been in there a while bu I had to adjust it because I've changed rim/tyre size recently.
Nismo dash is the main reason I had to fix the speedo. A big digital speedo is just annoying when it's wrong!
Drunkan, you've fixed the speedo, but the tacho looks like the reading is out of whack too. And what wheels and tyres are you running now? Pics please?
Oil change (my last bottle of GW Sougi s6000), and a yearly inspection of the turbo oil feed banjo. Was enlarged to 1.5mm last year.
Looks like I'll be changing to the new GW SYN-X 6000 for the next one.
I checked my banjo this week and it was squeaky clean. I didn't enlarge the size of it though.
Edited by slippylotion
Whether or not to enlarge seems to be a personal thing; to each his own. There's no question; it's cheap insurance to remove & inspect.thumbsup.gif
Autech 260RS
Stock bottom end
Stock FPR
Walbro fuel pump
Power FC
AVCR
Z32s
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Fujitsubo Cat back
Gutted cat
Turbosmart BOVs
312.5kW at 16.5 psi
272kW at 13 psi
Nice Build, bet its great to drive
I was just wondering how the Power FC goes with the 260RS, Im assuming you used the one specific for the R33 GTR/RB26
Did you have any issues getting it to work, does anything not work as its meant to.
from what i have read it "should" work fine in the stag but i have not asked anyone who has actually done it,
Thanks
Thanks
No problems here
Yeah mate that tacho is wierd....lucky mid 90s LCDs had such crap resolution. It consistently reads 500rpm high, not like the speedo that was a % wrong (ie wronger the faster you go)
I've got R34 GTR rims (finally clearning the brakes properly) and 255/40/18 Federals. No pics it's too wet :P
Also fit Z32 AFM today, total fail. SOmeone has played silly buggers with the Z32 AFM curve on my Powerfc and it's not running properly. I'll probably put the standard AFM back on until I can get a tune.
Thanks
I am running a R32 GTR PowerFC and the car runs fine, an R33 PowerFC would also work.
I Run a R33 PFC (on a R33 RB26) with almost identical setup, minus the inlet and hard piping kit, but I'm still around 20kw short of your power. Guess its time to order those Z32s and the Greddy kit then... thumbsup.gif Good to see whats possible with stock bottom end and turbos...
Found a little cubby hole for a oil catch can today. Hopefully will minimise the amount of oil going out the end of these bloody VQ's. Have to go to pirtek tomorrow and get some real hose- as usual the stuff they give you is massively shit.
you need one from an RS with hicas, or an ARX. but only vq25det
Not true. Pretty sure Craig said 350Z 5MT rear diff, but I'd have to check.
I think the VQ25DD front diff is the good one though, haven't double checked yet.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
