Here's a couple of rubbish pics of my car with the new wheels on 19*9.5 + 35 with 245/40/19 tyres. The handling is much improved.
I can't get the caps on because of the hub nut things but I think it looks good without the caps anyway.
I can't stop staring at the entrance way appearing like it's sinking into middle earth.
Your drugs, I would like to sample them... LOL
Yes the road falls away a fair bit into the gutter. I live on a big hill basically. Sorry for rubbish pics the battery must have been going flat.
Batteries dying shouldn't have any effect on how the photos turn out. User error? :P
Car looks good though, and I reckon some wheels just look better without the centre caps
Yes standard turbo. No afm cut. Running only 16/17psi.
Hey Josh can you be a bit more specific with the difference the intake made? I want one but don't want the AFM cut out issue or maxing the injectors. You have the standard turbo as well?
Hey Dale can you pm me the price on yur intake please?
Got under the car to see what was making the bumping and knocking sound in the front and rear.
Front - swaybar 'u' bracket bolt slightly loose and driverside laterial lock not square so knocking on frame.
Rear - ox underbody brace bolt loose, sway bar adjustment screws have come loose and were total wound out causing the sway bars to knock on rear lover control arms.
All sorted now. Just have a slight creak in the front nismo suspensions (sounds like creaky spring)
Also reinstalled the front underbody tray so all looks back to stock if you didnt know better looking at it.
Edited by joshm35
It's always a good idea to get underneath & lean on all the fixtures about 500km after you do major underbody work.
Particularly with Powdercoated parts like swaybars, as the coatings flatten out around bolt holes; & bolts can have more clearance when previously, they felt quite tight.
Ive npticed its spools quicker/earlier. Goot mid range. Nothings defined without before and after dyno results which I dont have as my car has not been on a dyno as yet
So josh is there more mid range, top end, all through the rev range? Can you advise what difference if any it makes?
Thanks
Edited by joshm35
Sprayed coolant all over my engine bay, exact source is yet TBD.
Thankfully the informeter beeped its arse off at me as temps rose up above 104 - let me know there was a drama before the cars temperature needle moved off 'centre'. I was able to pull down a side street and let it cool off, I was near enough my destination that I could just leave it there as well and then topped it up with some demineralised water to get it home safely.
Doing a pressure test tonight to verify its the radiator thats decided enough is enough or if I've got lucky and its just a hose.
Kakimoto r fitted this arvo as well as 80mm front pipe.
Not attempting dump at all craig can do that :P
Boost increased boost is peaking at 1.3 for a split second and power has increased.
Rear wheels now spin on stall and can load up 1.1bar to launch.
Can only see dump as improving what I have now.
Interesting looking at the stock exhaust setup. It has a pulley that goes from the car to a butyerfly valve that looks like a throttle body/cable that opens for the 'sport' mode.
Pics soon
changed the oil, found where the oil leak is, happy it's not the engine, sad it's the powersteering line below the aircon compressor, aircon clutch blew and looks to have nicked the power steering line
new spark plugs for me
interested to see what the difference will be on the cold mornings
old plugs were 60,000km+ old iridiums with a heat range of 7, new plugs were bcpr6ey-11's
God that pod is ostentatious.
Oh, it was my radiator that was cracked. Standard top plastic section. So I replaced that over the weekend. V35/M35 one off ebay, received it within 48hrs of placing the order and no modifications were needed. Good result, aside from it being a pita to bleed - but we all knew that.
My dodgy temporary fix involving a soldering iron (Apparently I'm a skilled plasti-welder) and some silicone sealant held up perfectly well on my 50km trip to my mate with a hoist too!
heat wrapped the Suction pipe and intake plus a couple of other bits.
Engine bay completed!
Good job! Zorst and front bar then done?
Looks like an inside out Pringles packet. :P
Nismo Pringles can + duct tape for ghetto drift points. Engeen is hungry for original flavoured air!
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
