They do seem to run a little richer on boost than OEM, I suspect they have a slightly different airflow/Voltage curve. Only the modified cars seem to display the rich running, at least it's better than lean mixtures I guess. Did you reset the ecu before fitting it Josh?
The problem is the 'replacement' Nissan AFM's run much the same as these, and only last a short time in comparison, (something gets damaged inside at full noise for some reason.) I have yet to hear of a failure from these aftermarket afm's, and the price is much more reasonable.
Gives you a good reason to tune the car Josh. :P
Yes a good tune is next on the list once I get a ecu. Was thinking wolf 3d(to give us another ecu option) or greddy emanage ultimate(already tried and tested). Found when I was giving it a little using triptonic once I went from say 1st to 2nd gear it kinda stalled/stuttered.
Well, I bought the red S1 off ebay. Price was OK for S1 Dayz with electric leather. Duco is sh#t but does not make it go or stop. Motor was advertised as stuffed, and it is. Compression test was my worst Chrissie present 3,5 & 6 50psi. So out with the motor and it looks like an RB30/25, same as the Sil is the way to go.
So my new year of Deeper in Debt continues. One would think at my age I would know better But then I am a Nissan Man.
Happy SAFE motoring for all for 2014..
Took the HKS pod filter out and put the factory air box back in with a Greddy high flow panel filter. Hopefully it will be a bit cooler than the pod filter and if I was to get pulled over, it isn't a defect.
Have you got a cold air deflector? That is supposed to help also.
Yeah, I have that. Kept all the stock parts just in case. Although it is a PITA carrying this stuff around when you get posted around the country every few years.
Hmmmm looks like your going to need a 4wd sump adapter and oil pick up for that mission
Hmmmm looks like your going to need a 4wd sump adapter and oil pick up for that mission And a lot of dosh.LOL
My Nismo son is doing the Sil Rb30/25 so he does the hard yards and I learn from him for a change. I have been looking at a better oil pump system
for my other RS4 Auto. It has an FFP and a pod and it runs a bit too hot and gets the gurgles I have an oil temp gauge and it gets to 120 when pushed up Henri Robert Drive.. I am looking at an oil cooler, but with a remote oil filter and an oil cooler I think I will need a much better oil pumping system. First I will go like Hanso and refit the stock air box and the cold air deflector. Mrs66 will appreciate the lowering of the induction noise.
Hugh have you put a bigger transfluid cooler on the auto RS4? If it is still routed through the bottom of the radiator that should help. I presume you are using a good synthetic oil! I had a remote filter system but gave up on looking for a place to put it so just got a sandwich plate where I can screw the filter on as its not too hard to do under the FFP.
And what have I done to my Stagea lately? Finally fitted the stock rear wing I bought ages ago, got my under mirror rust cut out and will paint shortly. I got tired of buying cheap and nasty wheels for the track and thought why don't I use my lightweight forged TE37s and bought some Direzzas to try. For the street I got a set of 18 x 8in wheels (ex Nissan GT coupe SE) which actually fit ok. I seem to have lost the ability to paste links on here (anyone else or is it my computer?) so pics will have to wait.
Also removed the knock-off Aerocatches which lasted less than 6 months and installed the much superior genuine article.
(BTW was having a number of problems with this site - unable to paste links etc. Just uninstalled IE11 and reverted to IE10 - all seems to be fixed)
"KiwiRS4T" watch out the heads of the bolts on the bonnet pins will rust out with rain, didn't have a problem washing my car but after it rained they left nice rust lines all down my bonnet :(
No worries have already replaced with stainless!
Tried to rationalise that it's just a car and was not worth commiting murder over because my mother-in-law didn't even notice she'd clipped another car with it pulling out of a car park. Nice little dent right on the crease above the driver's front wheel arch and scuffed up paint on the front bumper.
Mother-in-law is now banished to driving only the Commodore battle wagon which, every time it gets damaged, only elicits a "whatevs bro" from me.
You ought to see my two Stags. None of my doing.
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
