Pulled apart my centre console to eliminate the squeak/rattles from the shifter surround.
A bit of draught excluder tape & about 15 mins work; no more rattles! :woot:
After 3 years, I finally sprayed my trans cooler mount satin black; now you can't see the shiny stainless peeking out through the grille at you.
Also had to replace a broken gas strut mount for the rear door; it snapped off the other day & the hatch crashed down & belted me on the melon. OUCH!
Loctited in and a little rust on the thread; so had to drill it out.
Removed the opposing one to confirm the thread pitch (8mm x 1.25mm); noticed it has a rubber sealing washer on the flange that seats against the body of the car.
After a chat with Scotty; he commented that he's had several snap, and all were using the rubber washer. He also said later build cars do not have the rubber washer.
It makes sense, as the washer allows the threaded shaft to flex (and over time fatigue & snap); rather than the butt hard up against the flange, and let it take all of the load. The hatch struts exert quite a lot of load on the mount, so it's only a matter of time.
If you get a chance; it would definitely be worth the 10 minutes it takes to pop the bottom clip off the bootlid struts; remove them, take off the rubber washer (if fitted) and bolt them back in. You could take the opportunity to put a little dab of grease on the ball end to ensure smooth operation in the future.
Removing & checking BEFORE they snap is far easier than removing a broken thread AFTER they snap.
Happily; a replacement ball mount is easily available through Repco (supplied by Monroe) for $5 Is called "Screw Mount; P/N MLSMP351".
  • Like 2
Following on from pulling the whole rear of the interior out.
I vacuumed then cleaned the chassis with a wet rag then polished dry. Put the seats, floors, walls, mats etc back in. I then sprayed all the fabric areas and scrubbed to get all the stains out, let sit overnight. I then vacuumed the areas and moved onto the front of the interior. I did the same again with the centre console seats etc.
I also had enough time to clean all the door jams and give them a polish. Looks like a brand new car :)
Still have to leather protect and fabric protect the interior.
Next i will be spraying the side front and rear moulds silver to match the rest of the car as they have faded badly and no amount of elbow grease is bringing them back to an acceptable standard.
Does anyone have any good ideas on how to bring black window rubbers back to their glossy finish? Mine are chalky and 'back to black' didn't bring them back good enough for long enough.
Well after a few months of stuffing around, wrong parts being ordered and the body not being up to the task.
Looks like I'm finally on the right track to getting my brake upgrade finished, fitted one side up and pretty stoked with the result.
Also today I picked a turbo I had left with John at Precision turbos in Wetherill Park to be rebuilt. Standard turbo with larger Garrett exhaust housing, I also had a few actuators laying around and he picked the best one.
Estimated good for 300kw. Way exceeds my current expectations which is awesome........ can't wait to fit it.
Pics to come.
I'M EXCITE :woot: :woot: :woot: :woot: :woot:
  • Like 1
Ok, so after a grueling day at the gym on saturday competing in the in-house crossfit games. I forced myself to get amongst it today and finally sort out the brakes on my rig. Happy days... :woot::woot::woot:
Helen assisted with bleeding the brake lines. The boat pulls up nicely now. Only took four months to sort out.
I know I promised pics and I will post them up soon, just trying to upload a video to complete my Cert 4 in Business Sales.
AAAAAAAAAAAAAAARGH, its all happening. This will be me when it all done and dusted... :worship:
  • Like 1
Same here. :cheers:
I just fitted a pair of Ksport 8 piston callipers to the front, trying to increase front braking bias. Seems to have done the trick. The pads are twice the size of the 34 GTR Brembos I had on there. Still only a 330mm disk for clearance under the stocky V35 18's.
I need to find some decent pads for them now, as they have Bendix in them. :/
  • Like 4
R32 son brought home a "PUPPY?" I thought it was a Shetland. He goes to work 6 til 6. I get to do the exercising, which is actually a plus for my health.
Anyway the RS4 came with the cargo barrier and cover which had never been fitted in the 7+ years . So I fitted them today.
The dog, "Phoebe", loves it and rides around looking very regal
PS. Would have been good to have when the kids were growing up.LOL
Edited by 66yostagea
Same here. :cheers:
I have Pagid in mine
You don't happen to have the part number handy do you Bob?
The Bendix pads overhang the disk by 3mm or so, I want to swap them out sooner rather than later.
#@scotty nm35; get in contact with GSL Rallysport they will have a bunch of options depending on budget and usage.
The delivered from QLD to my place in one day.
Highly recommend.
Sorry can't find my receipt - but got them from RaceBrakes - I believe they are an AP pattern.
No worries. I initially wanted road pads and I would drop in front race pads if it ever went to the track again. After discussing it with GSL the A1RM's will be fine for both so I don't need to buy a second set.
I will concentrate on getting the Evo track ready instead I think.
Thanks anyway Bob.
Ok, so here are some pics of my set up with some braided lines thrown into the mix.
Passenger Side...
Drivers Side...
AND.....
Rebuilt standard turbo with larger exhaust housing.
Cant wait to fit this but will need a few other items to complement this and front mount already purchased.
Type 4 Nistune board, bigger injectors & Plazmaman FF Plenum(why? I hear you ask)........ Because I can, and they look the goods. Especially in mat black.
Stay tuned
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
