Got the battery replaced in the remote. No more green flashing key symbol on the cluster and the return of the inane joy of unlocking the car from 20 metres away. So joy.
  • Like 1
Just getting the car back on the road after a long period of rebuild and decided to replace the craptastic factory gauges in my 260RS with something a little more accurate and informative...
Left to right: oil pressure & oil temp, boost & fuel pressure, voltage & water temp
  • Like 3
well i got my nm35 back from my mates garage after about 10 weeks. it now has the first uk built highflow turbo fitted & some new bc's coilovers fitted. as it was in the garage my rad got a leak in the fillerneck so had to get one from a nice lad on here. & tomorrow im off wheel shopping.
  • Like 1
Was bored and instead of working the long list of things to do/maintain the stag, i threw it on the Dyno instead to see if it's running fine, not lean as i got Impul Ecu in it now ........
Confirm it's all good, still running Rich as but better than lean i guess.
Dyno in 3rd gear, have 2 pre-run to make sure everything is safe, 3rd run is the power run for fun.
Was going to run in 4th gear but the gear box was heating up so we scrapped that and so now i really have to get off my ass to fit the trans-oil cooler.
Drill out a broken bolt in the intake manifold, replaced with high tensile grade 12.9.
Clean out the throttle body while at it, did play around with the butterfly and lucky enough, the idle is still fine, didn't have to do a re-set.
  • Like 1
So some of you (most of you from Facebook lol) probably know that the stagea was involved in a crash about a week ago.
IMG_1486364535.793506.thumb.jpg.85651443
Damage was as follows:
IMG_1486364589.983151.thumb.jpg.915a97a4
IMG_1486364620.205857.thumb.jpg.c4a49b11
IMG_1486364638.310276.thumb.jpg.d1f9c061
IMG_1486364662.884735.thumb.jpg.df29364b
IMG_1486364780.568453.thumb.jpg.450a80f0
IMG_1486364819.884065.thumb.jpg.9cfe38eb
Honestly not too bad damage for how it was hit, I'd consider myself lucky lol
Today I got some parts (thanks Liam!)
IMG_1486364708.766300.thumb.jpg.dcbae32c
IMG_1486364721.410057.thumb.jpg.da8d1a5e
While the door isn't in pearl white, silvers good enough for now..
I'm going to most likely respray the car in the future anyway.
Here's hoping I can get this subframe in and the old one out ASAP
  • Like 3
previously posted pics of LED High beam install, had my guy put in some LED fogs while I was out of town a few weeks back, no install pics just in action
Fogs with headlights off (just the daytime running light inside each headlight housing)
All of the lights (factory low beams, LED fogs and LED high beams)
  • Like 2
So it's been a pretty successful few weeks or how ever long its been lol. I'm going to try and do this in chronological order but dunno how easy that will be. This will also consist of lots and lots of photos so I apologise lol
First off, I swapped the door over. Only thing is that the inside door handle wasn't working and now after about a week with the door on the outside one isn't working... rip. Lucky I have a donor door :P
The ding still needs to be removed and painted.. got quoted $1200 which just about killed me... so dunno what i'm gonna do there, door still seals so maybe I can live with it till I can get it done and the money bank has some dough. The silver door just gives the car personality right?!?!?
Annnddd the solid Hilux to carry the parts lol
Now. The goodie. Subframe removal and putting the new subframe together but not in,
Considering my uncle and I didn't really have much to go off for directions besides the quick google and got the base stuff figured out we just went straight into it. Didn't run into any issues sides the handbrake cable cover thing getting pulled out and the metal bit getting a bit bent around the edge, but we aren't too sure if we did that or if it had happened from the crash.
IMG_3242.thumb.JPG.0523164503a26052fb056375ecd06a0c.JPGIMG_3243.thumb.JPG.dc18295488523a99764dba25fd3f9091.JPGIMG_3244.thumb.JPG.8d015bcaa8a31c4a39f38f69582cf729.JPGIMG_3245.thumb.JPG.ef25093648244a50080a12ebb1586c02.JPGIMG_3248.thumb.JPG.275cf1d343578a850bdaefbb0b17a3f4.JPGIMG_3253.thumb.JPG.c541806c874f2d12af800234cc572fcf.JPGIMG_3259.thumb.JPG.a0e42e6e75c0630082a863bffe78908d.JPGIMG_3261.thumb.JPG.d95fe773d47e9c12b4d537e816f57e73.JPGIMG_3264.thumb.JPG.49a262e02da8956fd927f90cd78b3c69.JPGIMG_3266.thumb.JPG.61cb1efed4cc3a5d6ce7fad5436e3c62.JPGIMG_3275.thumb.JPG.d89733f74d7e169525707445a048d08b.JPGIMG_3276.thumb.JPG.b0baec7e6265e34c41c470fe5f8af00a.JPGIMG_3289.thumb.JPG.4f9869e33883809fcb6c4a7bc501a7ca.JPGIMG_3299.thumb.JPG.9a6c3d645caa4f7b3cc76b0b11e63b2a.JPG
Check out the shock though >.<
I think all up it took us 6-ish hours, we took our time I guess,
I picked up some V35 coupe rims?? 18x8 30p, my old wheels were 18x8 35p. I honestly don't think they will look that bad.
IMG_3331.thumb.JPG.910ca646bfe3eb10be0edcea654c8131.JPGIMG_3332.thumb.JPG.67d950547e25f1729fafc03af7599d7a.JPG
So that's about it... Subframe should go in the weekend after next.
They will look great on your car, I've got them on mineIMG_0369.JPG.622067ee0ab1416658792ec948a86111.JPG
Yeah they look pretty good on yours, I kinda want to get them powder coated but I'll see how I go lol.
Can't wait to put them on! [emoji2]
  • Like 1
Yep, I'm guessing because your car is white, a slightly darker colour would work well. I've never been a fan of black wheels, though - what's the point in having or buying nice new wheels if you can't see the detail in them.
  • Like 1
17 hours ago, JZMX32 said:
Swapped out my brakes this arvo
Front and rear 370z Akebonos
Endless rotors and pads
Braided lines
Whats the part number and where you got them from? Mainly the SS lines.
That looks like some decent bite there.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
