2 hours ago, NicPM35 said:
Here's a quick vid of my previously mentioned exhaust. Couldn't make too much noise because I cbf driving miles away from suburbia
Holy that sounds mint!
  • Like 1
Sound deadening in spare wheel well, makes big difference to resonance on the highway, more of the stuff coming to put in the door skins and rear quarters very soon, then the big banana will be cosy quiet
On 03/12/2017 at 10:40 PM, Long and low said:
Where did you get your sound deadening? Cost? I'll hopefully get a vid up of my exhaust this week
Got it on Wish, took a few weeks to get here but bucketload cheaper....
One sheet big enough to replace the bonnet card and wheel well was $36 delivered, its 10mm thick and compresses to 6mm.
I'll try finding the link to seller and Chuck it up on here for interested parties.
Edited by oxford1327
  • 3 weeks later...
Just picked up these Rohana RC10 wheels. 20x9 and 20x10 with about 43 offset I think.
Ended up needing 5mm spacers on the front because the offset wasn't quite right, so chasing up some longer studs now I think. Not much thread left with the spacer and the wheel.
Both ends sit out of the guards about 3mm, so should look perfect when I get some lower spings. (anyone got spare lowered springs??)
I could sort a deal out with Springs if your in nz? I'm going to put in adjustables in the new year
19x9.5 +22  -cobra lows
  • Like 1
1 hour ago, Long and low said:
Good improvement.  I couldn't bring myself to sell my Autech rims. They are just sitting in the garage "in case"
Spot the Easter egg....
Chopped? :P
  • Like 1
9 hours ago, m35stagea said:
Got the shits with stock afm and instability in the nm25 so trialing the z33 r35 unit.
So do you have to (can you) retune the ECU to suit?
Are you saying the Z33 is the same AFM as the R35?
And will the same unit work on the VQ35DE?
Installed the RS-R lowered springs from eBay, plus some new 20x8 Vertini rims which fit properly without dodgy spacers. I won't admit how much time it took me to swap the front springs, but in my defence I had about 1ft on either side of my garage to work with.
Pretty happy with the outcome!
  • Like 7
So last weekend I did the lower arm bushes , radius rod bushes, sway bar bushes,  lower ball joints and the AFM . My press groaned on some of the bushes. Those things are in there very very tight. The ball joints are a prick!
Ride improved but it also highlighted just how bad my shocks/springs are. Midday today picked up a set of nearly new Tein GT Wagons and a R33 boot brace to make up a front under body brace.
Fitted the fronts gonna do the rears tomorrow morning, got late for the rattle gun to be going. Took it for a quick spin around the block , holly crap the difference is incredible.
My IT monkey hands are hurting and im cut up but it passes the shoe test.
  • Like 2
Rear springs and shocks done, front underbody brace bolted up. Its now a totally different car. Why did I not do this sooner :huh:??. Drivers rear shock was completely buggered. Could squeeze it down between  my hands and it took upwards of 3 min for it to extend.
I set my heights on the bench. Will let it settle for a week and then set again. Just need to buy some C spanners , anyone know where I can buy some in Perth?
Of course all this effort has brought my attention to another clunk. Passenger side tie rod has play. So now need to find a set before I go get new shoes and an alignment.
Suspension sorted now set my sights for go mods:)
  • Like 3
I'm long overdue posting an update.. don't even remember what the last thing I posted was lol
Anyway, some stuffs has happened, most important one is that my car no longer pings... Took it to E&H Motors out in Pukekohe and they found that the timing was off, which is what I had suspected. A fair chunk of money later i'm happy that the car is now 100% better.
On a cooler note, I bought a LSD diff which I was gonna chuck into a 4WD stag casing but I derped and forgot about the ABS stub axles.. so now I need to try and find some 3x2 LSD ABS stub axles that I can use... otherwise I might try find some 5x1LSD ABS stub axles and put them in it, but that involves buying the axles as well...
IMG_0518.thumb.JPG.47145efa2bcb69db02e993f1c1860fab.JPGIMG_0517.thumb.JPG.8ad87bed83f34ddb4bbf91a4b2b8cf00.JPG
Also got given a spare casing, but I can't use that anyway.
You can see the ABS ring on the stub axle that I need, apparently the open diff one that I have is too short to be used in the LSD unfortuantly.
Also changed out my coolant and changed spark plugs/coil packs to brand new ones.
Other than that nothing cool has happened haha
  • Like 1
Just pressed in a new bearing for the AC idler pulley. Statewide sold me a 6301zz for 5 bucks cause they had em on shelf but not in the POS. :3_grin:. No more howling AC huzzah!
Looking good! So what offsets work on the 8 in rims? Different front and rear?
  • Like 1
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
