To overcome some current boost issues and in anticipation of things to come I fitted an Eboost2 HP. Works well it’s only a stock turbo so 10psi is it. It works well. It also has the dual shift light on it
45893015_2201894890051722_8361689472860946432_n.thumb.jpg.c5746e4eb0e3943d6b8f5c3613fc4f78.jpgInstalled some BC coilovers on the weekend, and finally got round to fitting the rear 350z brembos.
FYI 350z uses different rear brake lines to Stageas. Bought a set of steel braided lines for a 350z brembo setup, the fronts fit fine but the rears use a different connector to what the stagea has.
45 minutes ago, Long and low said:
That's good to know about the break lines.
How mong did it take you to install the bc's? I have a set for sale but I'm always tempted to just put them in
Rears were a breeze. Fronts took a bit of persuasion with a jack and some other tools
  • Thanks 1
4 hours ago, Hertz Donut said:
Bought it a Honda S2000 garage-mate to make it feel fat and slobby and unloved. VTEC has allegedly been engaged, all of you.
Pics!!
Nothing handy, but imagine a slightly portly, balding, middle-aged bloke saying "oof!" as he attempts to wedge himself behind the non-adjustable steering wheel of a small, red roadster. That's meeeeeeee!
PS: All the rpms work. I checked. A few times.
Edited by Hertz Donut
  • 3 weeks later...
Spend the day fiddling with the rear BC coilovers.
This is as low as I can get them without the shock almost being maxed out.
Took out one of the locking rings and even the lower rubber mount. (dodgy yes I know)
But any lower and the spring will literally fall out going over a bump.
Anyone else have trouble getting real low on the rear with BC coilovers?
The front seems to slam easy no problem
I've been gone a loooong time. Old stagea blew a fitting at the back on the firewall and lost all my coolant.. temp gauge never moved and ultimately killed my engine. Spent a couple months without a stagea and really missed it.. so here I am again, just picked up this RS-v on the weekend, 25DET manual rwd. Sunroof too. Extremely happy
  • Like 3
34 minutes ago, KiwiRS4T said:
Very nice. Wheels look ok too! Got a budget for mods or have you spent all your money buying the car and have to save up?
Cheers, no budget for mods yet. Just want to enjoy it for a bit first, quite a bit different to the old slow 25de 4wd stag I had beforehand. I just need to change the BOV to a recirc one as the car idles quite rough at the moment. Otherwise its pretty mint
This is with standard shocks and cobra lows. I have bc gold to go in. I'll be pissed if they are no better.
Are you referring to the BC BR kit? Because that what I'm using.
Maybe return them before installing if you want to go any lower than mine?
Although I'm not sure if it'll be the same story, assuming yours is AWD rear anyway and uses coil on shock rear?
Edited by NicPM35
Installed Audi R8 coilpack conversion kit from 5-0 ignite, had to do some intake mods for clearances, otherwise would need to have changed to front face plenum and costs/other mods weren't desirable at this point
  • Like 1
Do you have a tuneable ecu or were no adjustments necessary?
Got nistune in it, but didn't need to change anything for it to start and run fine so far.
Once it goes back to dyno will alter the dwell time as per recommended by        5-0ignite that make the kit.
Thus far car runs and idles smoother, as well as no longer seems to stutter under high throttle load, whether that's the old noggin playing tricks remains to be seen once dyno sheet is compared etc.
On 12/12/2018 at 8:27 PM, Akshunhiro said:
I've got MCA coilovers in mine and they go nice and low in the rear. Josh did a true coilover setup rather than separate strut and spring setup from stock.
Does that mean the rear weight of the car is now on the 2 small bolts holding the original shock in place? Assuming the spring is no longer in it's perch
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
