On 9/2/2019 at 3:00 PM, TMLP said:
Ok bottom end done full NITTO 3L grout filled & brace adapter for the sump & front diff. Waiting on the head ?
Head should be back from the machine shop tho week. Gone with big cams & valves, springs a shimless setup  plus  rear head drain & NITTO oil pump. Getting close.
  • Like 1
Pulled out both hubs to replace bearings only to find I need ball joints, cv boots & tie rod ends as well....
You would think Pedders would have picked up on this when they did their inspection and told me they crushed the ball joint when they put it in.
Never going there again.
Started extricating the stagea from the garage today.
planning to get it back on the road. just need to fit the cupboard full of parts i have for it.
5 hours ago, TukeH said:
Just one thing what I have been done 1month ago.
Went cardealer in southern Finland and chance my Stagea to this
Cool - more info and pics please!
Honda Odyssey absolute 2.4 k24a2 engine.
Only 200hp and FWR it is slow otherwise its much better driving than stagea and its more eco friendly 6-7l/100km
Future plans. air suspension and new rims
  • 1 month later...
Ok it’s gong in here are some pics as promised.
  • Thanks 1
  • 3 weeks later...
So on the Maatouks racing FaceBook page..
www.facebook.com/maatouksracing/
Shaun’s stagea came in for a MR 700 package packing a RB30/26, 6 boost manifold, garret gtx35/84rs, Turbosmart 50mm wastegate, ID2000cc injectors,custom cooler pipes and catch can all controlled through a Haltech plug and play ecu with all sensors and wideband for engine protection and peace of mind. Making just under 400kw @ 16psi at only 6000rpm on a running in tune.
6 hours ago, Duncan said:
great outcome from the engine these cars should have left the factory with :)
let us know how it goes once you lean on it a bit.
1000 k's on low boost the retune on E85 then I'll give it a bit & let you know how much I scared myself
40 minutes ago, KiwiRS4T said:
My C34 was pretty quick with 320awkw - yours should really shift with 388 and should be fun on the track with over 400!
I hope so, its going to be interesting to see how quick it is being so heavy after run in & the E85 & boost turned up ;)
On 11/30/2019 at 2:04 PM, RBW49N said:
Fitted this the other day so comfortable
What rails are you running with these?
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
