  • Replies 296
nice one mate. you will love the hollinger, best money you'll spend on the car. bet you were impressed with how compact and light they are for such a stout 6 speed sequential box? they are a better thing in every way. better gears, better engagement, sequential, better casing and on and on. well worth the $20odd thou. espcially considering doing a full house gearset upgrade in a stock housing these days can run to $13-$15K by the time you do all the little upgrades and have it all assembled. no such drama with the hollinger and they are so nice to drive. :)
lol, thanx guys =)
what compression BC stroker kit are you using?
i'm unsure. powertune know more about it than i do
hahahaha i hope your not wrong. =)
I've heard mixed reports about the hollinger. The good is they are bullet proof, ultra fast to shift etc.
The bad was (as I was told from someone else with a hollinger and 800+hp), the car lost what street manners it had left. Thats fine if you use the car as a toy that you occasionally go for a blast on the street or race track. But you cant drive your mum to the shops in it anymore. Based on what you said the cars fuel consumption is though, Im guessing its a toy so you will probably love it.
As long as you remember not to come to a complete stop, at an intersection, in 3rd gear, with cars waiting to turn behind you while you attempt to select lower gear but you can not. So always when downshifting, car needs to be moving at least a little. That is the only downside on the road, but than again there are too many positives to worry about any negative.
Enjoy the box. Once you setup your quick shift, up-shifting is a pleasure.
:thumbsup:
yeah they are definitely not that street happy. I mean you can't just cruise off and whack it into 5th or 6th and cruise. need to shift up and down the gears through every gear which can be tough if crusing in 4th and suddenly have to stop and quickly row back 3 gears. but like most things you would get used to dealing with it. also sucks in carparts as you sit there trying to grab reverse which can be a pain as you have to go into 1st, then into neutral, then into reverse. try doing it 3 times quickly in a 3 point parking manoeuvre!
but the joy under full power on the circuit makes them well worth it.
LOL Pete! Plenty died after 1 run, some lasted two :D
Was good to see this car in person. Gearchanges were just silly, that alone is worth 20k!
Needs some work round the launches to get outta the hole better and it'll be ridiculously fast!
Even i was a casualty on my last run, but it was expected :D
I remeber your car, what happen to it?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
