Mat doesn't do skids, he just launches at full throttle :P
Why launch at half throttle? That is uncool....
Gave the Hankook 275s a workout!
do a skiiid faggggoooottt
:woot::banana:
This. Yes.
Round up the Horses boys... It's Goulburn Gatin' time!
:rofl:
Oh man that was a good event! Cant wait for the next one.... On that note.... ASH!!!!!!!! Where are the SAU NATS this year? Finally i might have a crack lol... Only taken 2 years!
What did you think of the rs3 rubber?
Man it wasnt a good enough indication to get a feel for the grip levels... From a standing start it was useless BUT most tyres will be with 500+ rwhp and RWD...
Will have to let you know on the 25th, best i can do...
Your rims for some reason always look massive.
But I do love skids <3
22's brah! Actually i am not sure why they look so big... I love em though!
Have new rims for track use on their way too me!
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
