OK, so my question is,
What difference did you see from JUST adding an aftermarket intercooler?
Boost increase?
power increase?
lag increase?
better/worse drivability?
etc?
I have a 33 with basic mods but standard boost and while im not planning to go all out on power (spending the money on suspension and other instead) I did wonder if there would be much benifit alone from just wacking on a FMIC.
I know there is alot of BS and lack of knowledge about this stuff, so actual experiences and info please : )
thanks all
https://www.sau.com.au/forums/topic/358469-what-happened-when-you-added-a-fmic/
My experiance
GTT:
Slightly more lag, throttle response tad slower, small increase in power (before tune)
GTR:
Small increase in power (before tune)
I would go ahead and do it. If you've got all the stage 1 mods done, go ahead and get it tuned on the dyno and enjoy the ride thumbsup.gif
More lag, about 20-30Kw gain with standard ecu. Did alter drivability for me, only because before the FMIC was installed i was very happy with near instant spool with just pod and full turbo back exhaust.
GL
Boost increase?
power increase?
lag increase?
For my R34 GTT with a 3" turboback exhaust - I didn't notice anything after fitting a Blitz return-flow - lag, power increase, boost increase, etc. All seemed about the same?
To be honest, the only real thing I did notice is that in summer I had less issuse with the car feeling sluggish on the really hot days?
if you go from std SMIC to FMIC and change nothing else
no power gain
loss in throttle response
slightly extra lag between open the throttle body and boost response
i cannot see any way you would GAIN power by changing the core size and adding more pipework at the same boost level
if you turn up the boost, tune it etc then yes youll make power, but just by chainging core and pipework = 0 rwkw gain
no power gain
So the dyno was lying? :blink:
EDIT: Just found this and it explains quite well.
"So, in a nutshell a front mount intercooler cooler upgrade will NOT make HP in your Supra, but it will free-up power that has been lost from inefficient intercoolers and most importantly it will maintain power for a longer period of time and reduce the chance of deadly detonation."
http://www.suprastore.com/dofronmounin.html
Edited by Shazza24
i went from 11psi + r34 smic + full exhaust + tune >> to 13psi + fmic + same exhaust + new tune.
it makes more power everywhere, and more consistantly than with the smic. throttle response suffers a bit, and you will notice it.
but for out and out WOT adventures, fmic feels better.
i noticed straight away more mid range torque, and a freed up top end. Also was consistently faster.. with the SMIC it would be ok if i hit it a few times but after that you could tell it was heat soaked.
I installed a Return flow fmic and noticed no difference in lag tbh.. Fuel economy was terrible though, 250km to a tank untuned, The smell the car made was nice though haha
pfffffftttt.... i noticed SFA difference when adding a front mount intercooler. the only thing that happened after i installed it was i then had piece of mind that i could safely turn the boost up or upgrade my turbo.
i've had 3 RB powered turbo cars now and done the FMIC upgrade on each of them and on each occasion there was no noticeable difference, no increase in lag, no increase in mid range or overall power, no decrease in response. though, if i kept telling my self there was a noticeable difference i'm sure i would start to believe it. after all, nobody wants to say that they spent $600-$1000 on a mod that has no noticeable effect.
a FMIC is in the same group of mods as bigger injectors and Z32 AFM's, while they don't add any power to your setup they support the ability to achieve more power with more boost, or a bigger/hiflow turbo.
Edited by QWK32
Disagree^
Reason being: I spent $800 expecting no difference, thinking I would have to wait until I had upped the boost before I saw anything change. So there was no placebo effect or post purchase dissonance at work here. On the other hand, the fact you haven't noticed anything across 3 cars maybe points towards you not being as in tune with your vehicles as others may be :)
Slightly laggier. This is to be expected with more pipework and a bigger core.
Slightly more power. Remember that intake charge temperatures are much more than ambient temperatures...consequently more exposure of the intake charge to ambient temperatures is going to be better at cooling it. A larger cooler core is also more robust to changes in heat. More consistent performance on a hot day thanks to things like this.
Dynos have shown differences between FMIC and side mounts on the same boost. Full benefits can't be seen until you up the ante, so don't expect a radical change in the way a car drives, but a front mount does make a difference straight up.
Disagree^
i'm not disagreeing with the fact that a FMIC will help maintain a more consistent performance well after the stock side mount has succumb to heat soak. but that isn't an increase in power, its the normal expected power being maintained, were as with the stock side mount you may experience a decrease in power on those particularly hot days, after a bit of spirited driving, or have reached the limits of the stock setup.
one thing that does happen, and i have heard/seen plenty of comments about it, is that after installing a front mount an increase in standard boost by a couple of PSI can occur. that could be playing a part in some people's experience of more power after installing FMIC, especially if your not running an aftermarket boost gauge and can see the increase in turbo pressure.
Well I just got a Just Jap return flow FMIC (the black one) installed & didn't really notice anything different compared to before. Car felt more powerful but that is probably just in my head :rolleyes:.
On a related topic, does the additional of a FMIC warrant a re-tune?
I had a SAFC 2 tuned for my old set-up (which consists of turbo back exhaust, R34 SMIC, 10Psi boost Tee & POD), now that I have replaced the R34 SMIC with a FMIC, do I need to get it re-tuned again? Or would my old tune be sufficient for the time being?
Keen on putting the car on a dyno again to see if there is any difference compared to last time.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
