Unfortunately the new custom sump was modelled on an R33 and it didn't clear the swaybar enough when we put it in last week.
Because of this we missed out at PI on the weekend. I had brand new rubber on the thing and was ready to go but no such luck...
Turns out that the whiteline sway bar that is on my car was a prototype from years ago and they don't sell them anymore so pretty unique situation. The bend is very close to the sump so that's what has caused the issue. I think that a new 27mm sway bar with a better option that pulling the sump off again! Custom one being investigated now. Hope it makes the 21st!!
time for another update...
New 27mm swaybar has just arrived to solve the sump clearance issues. I currently have a loan 24mm until I get a chance to fit the 27mm. Might try both on the weekend if I can as a comparison.
Fulcrum suspension have sorted out the bar for me.
I've extended the wing end plates as the old ones were a little small and the bigger ones should hopefully stop a bit of the spill over the sides.
The splitter has come a long way. I'm still testing as it's all a bit new to me still. I'm really just copying what the fast guys do and following basic principles and advice I'm getting along the way.
I'll be logging the data at Philip Island this weekend to see if straight line speed is sacrificed and if corner speed is increased. As a bare minimum I'm expecting more downforce from just the splitter seperating the air and minimising air flow under the car.
If it all works the plan is to make the parts out of carbon fibre down the track. It's all trial and error at the moment.
loving the alloy canards. i made some about 3 years ago and was laughed at. been hesitant to make any new ones.
i seen in a build thread for an american R35 time attack car they made canards out of alloy. they were far easier and cheaper and did the same job.
are the uprights for your wing an off the shelf item?
Yeah the ally is pretty light except for the splitter. It's damn heavy. CF would be so much better
Nah they were made by superleggera carbon fibre in sydney. They're pretty hard core!
oh they look like a production type thing.
do you have any bracing under the boot lid? i may have missed it.
Hope you don't mind Russ. Most people probably know what happened already!
Russmans R32 GTST blasting around PI in it's last shakedown before WTAC!
For the full article check out Autocult -> CLICK HERE!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
