Great result tonight with the tune, these things throw out some torque let me tell you. Cihan was stressing about the rods when he saw it was putting out more torque than the 470wkw Supra he just tuned.
Ran the GTX up to 25psi, falling to 21 by redline. The boost snaps on even with the 1.06 housing. We had to stop there as I blew a cooler hose clamp and the 1000's were at 85% duty. There was still plenty left in the turbo...
The car drives amazing even though the power wasnt much better than before. (Perhaps the manifolds are holding me back?) :whistling:
Thanks Alex, you will be there soon. :)
You can clearly see the throttle closing at the top above 6500, not sure why. Redline is 7600 but the ecu is too damn smart. F-con will be the next mod I think. :cheers:
imagine how much torgue it will make with the 3.5lt then :thumbsup"
did you get new wheels Scott
I don't think the 3.5 is needed anymore, the 2.5 is plenty for me for now. :)
I put stock V35 8 inch rims on for the stealth look, with crappy Blue Streak tyres. The sidewalls flex like jelly compared to the KU36's.
wow! thats an awesome result! Well done mate! I cant imagine what 1000nm of torque feels like! Love the stealth look too - but damn those wheels are clean!
Thats not engine torque its tractive effort. But it would still have a heap of torque.
Nice work Scotty. Sounds like a decent improvement, even the though the dyno sheets don't make it obvious (to me at least) so well done :thumbsup: .
Apparently the dyno wasnt run in correction mode back when I tuned the old highflow, it was running around 10% correction last night so it was a 30kw gain on the last turbo which is why Ironpaw was having issues getting the same power. It is definitely an improvement but I cant use it due to the noise. :whistling:
Hmm I thought I wasn't getting the same power cause I was only running 17 psi?
Perhaps, I have no idea. I ran mine on the same dyno but before Cihan bought it so it could have been set up wrong. Only way to tell is to ramp yours up I guess. :)
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
