soooo i couldn't help myself, and felt i needed to add my own touch to the car.
Midori and the previous owner had already made something very special, and mechanically/performance wise, there really wasn't much else to do! hahaha (well, short of getting a RIPS RB30 or something crazy like that) - I did change ECU's and get the Flex-Fuel going thanks to Trent @ Chequered Tuning, but we only changed the ECU as we couldn't talk to the one in there unfortunately. So, running at 400rwkw on E85, and having more handling performance than i can currently even being to explore due to lack of skills, i moved to the exterior...
And really, could it be anything else? :D
- Nismo R-Tune bonnet
- Nismo Z-Tune front bumper
- Nismo Z-Tune front guards
- Craft Sqaure TCA-F Carbon mirrors
- Nismo LMGT4 18 x 10.5 +15 w/Advan Neova AD08 tyres
(yes, genuine Nismo items)
The parts have been on for a while, but whilst Matt was selling his car, i thought i'd keep it quiet so as not to reduce the uniqueness of his beautiful 34 whilst selling - aaaaand then it took a while to get around to taking pictures :)
Paint is off the gun (by DT Panels), nothing else has been touched after painting (as per my request), wet sand and polishing action to come, at the moment it's just a washed car a few days prior to the pics (don't even think there is really any wax left either). Hasn't been detailed in a while.
Anyways, hope you get as much enjoyment looking at the pics as i do :)
cheers,
daniel
https://www.sau.com.au/forums/topic/370313-midori-r34-gtr-v-spec-ii-nur-v20/
hahhaha, she does get a bit of attention
paint is WV2 - i might be biased, but i'm thinking i'd almost would choose WV2 over KV0 (Ztune) - i think the slightly darker shade is a bit more fitting the aggressive look, especially with black rims.
thanks for the comments everyone :)
lol @ Hamish, i thought Matt's car was still in Melbourne, still competition getting around :thumbsup:
Yeah Jamie, all those other body parts have been moved on, had to go genuine Nismo really... wouldn't have seemed right otherwise :D
It's the only way Dan!
I would have done the same, if owning a R34 GTR.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
