Ever wondered how big an ECU was...?
The file I have is just 1mb of binary. For a very complex machine, the file is kinda small I thought....
When you're not making pretty pictures, you can cram a LOT in to 1mb. Im actually surprised it is that big.
Looking forward to hearing of your success with Uprev :cheers:
Well, today I dumped the ECU with the UPREV software and cable. 3 and a bit hours of waiting! Oh well. its done now. I have emailed it off to Abbey Motorsports in the UK. They are going to tell me if I can use the uprev software, which I am almost certain I can, and give me something able to be tuned and flashed!
Forgive my n00bishness but could something like this be used to dump a VQ25det Nismo ECU and then flash it onto a standard VQ25det ECU? Sharing the increasingly rare awesomeness with us all? I know our ECU is different but if we were just basically copying the settings from one ECU to another?
Well not exactly. The Japanese, places like G-Zone, can remap the VQ25DET ECU. Not a direct swap of the Nismo, but probably better because it's tailored a bit more.
Not entirely true that statement.
The Nismo is not an off the shelf ECU tune but it is tuned on each vehicle that the Nismo ECU is fitted. Removing most of the low RPM throttle restriction and improving response all the way through the rev range.
you thought wrong :P
thats why there are no part numbers for the ECU, they are unique to each car. however AFAIK they are done with the factory options so we mostly have those as other brands.
I bet no Nismo ECU is tuned for a car with a big fat intake???
As far as I can see, the problem with any of these pre-programmed ECUs is they can't be optimised for our cars which are all a bit different. In some way they have to be "best fit". If only some enterprising person over here would learn how to hack the damm thing & offer customised tuning. Otherwise we continue to tinker around the edges without getting right inside.
At the moment I don't think the volume is there for the time required to hack it. Can't see anyone putting in all the time and effort to tune maybe 20 cars in Australia that would want it done. This is comparing it against S13 and the likes where they would do more than that amount in a week.
Remember that some people tune for economy and performance, I suspect that a lot of people that buy an M35 for reliability and purpose would consider getting it tuned to improve economy too. There's more and more of these things kicking around Adelaide (and just about every one I see is modified), so I can't imagine how many are in the Eastern states!
The way I see it you guys have these options-
A) Go to the Russians. They might be crazy enough to pay for someone to do all the work (on the other side of the world they're probably sayin: Австралийцы достаточно безумен, чтобы сделать это )
B) Get G-Zone or who ever to licence their technology and some workshop in Aus buy the set up off them.
C) Deal with what you got, because I don't think anyone in Aus is going to crack it.
Edit
D) Motec. forgot about that.....
Thoughts?
Edited by PN-Mad
I reckon someone will at some point.
I have a spare ECU that I can send out and had a place in mind down here (they create racing ECU's and are in Bayswater I think), but I can't remember their name to contact them :(
A good mate of mine is one of the 2 guys that are Nistune and I asked him a while ago about cracking it and it's not worth their time at the moment as the market is too small for the time needed compared to all the other models they have on the go.
Its not only the market, but Nistune haven't moved into anything with a CAN Bus electronics.
Stuck in tractor land....
Spoke with him again. It's because the newer stuff is flash based so totally different to what they sell now, here and world wide. So it's an all new R & D for it. He said its something they will look at in the future but not any time soon.
They are very busy with the current Nistune gear. They have done an awesome job making tuning affordable for the cars that are currently supported. And keep in mind that this is a 2 man show.
Edited by slippylotion
So because a few of us m35 wankers need something it becomes out of their league? Your most welcome to crack if your all so capable!!!
And let's not rubbish a business for not yet looking into something we want in low volume. I was simply letting you guys know the outcome from me asking them about it
So stop the rubbish talk, we aren't children!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
