I fail to see the conflict mohs a lot of things ... But surely not a sick kunt?
Well he was using "sick kunt" in a derogatory manner so...
For anyone that has missed it, this video seems to be doing the rounds
*tried to embed but failed
Wow 50 police to go and defect cars, obvious where the priorities are...revenue vs. prevent immediate and direct crime that actually has an impact on peoples lives. Love how every car they pulled over was either a P plater or modified looking vehicle. Nevermind the myriad of cars on the road that have shitty tyres or rust buckets waiting to crumple. Top comments were hilarious!
Love how the cop says if you modify within the confines of the laws then you won't have a problem...except for being pulled over for a 20 minute inspection, or having to pay to get your car tested (not to mention the time involved) on a cop's assumption it may be illegal. If they did this to all cars and drivers I wouldn't give a shit.
Got new sway bar links cos one of them was clean snapped, spent 1hr trying to fit just one side to the hardest setting on my sway bar with no luck... Surely there is an easier way? Anyone know any tricks? Used the trolley jack pole to move the sway bar and still nothing....
Sway bar links are whiteline, incase anyone was wondering
Did you jack the car from the k-frame? Both wheels need to be off the ground.
Bashing related death vs motor vechile reated death. Would like to know that stats.
As i see it there would have been multiple people in hospital because they chose to 'go out to the city' vs the road fatalities for that night. Common sense doesnt preval obvoiusly as making sure the car is quiet carries much the same weight as making sure people are safe on a night out...
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
