well well well whats been going on in here?
on another note anyone interested in some r34 gtr specific stuff? i got a stock catback exhaust also i power FC that im selling for $650 and also got some tie rod ends and some new suspension bushes.
He didn't chuck them up on JDMST.... LOL! Probably thought you were randoms who dropped by. Haha,.
Have asked for access to the dude's flickr, you just have to wait now... :P
Edited by PENGUYEN
yeah its a beautiful car, the colour has always been my fav of the gtr's.
I just paid the insurance for it, wasn't too bad, good thing I'm 27 so don't have to pay higher rates!
How much you want for just the stock rear muffler? Don't need the rest of the exhaust
tripod
long exposure
and a trigger flash light
you can see in the 32R shot a ghostly blue figure on the far left
that would be the guy running around the car holding the trigger light next to so that the light floods in
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
