Read up on it when I bought rays lightweight wheel nuts.. Apparently a saving of a few grams is multiplied a fair bit when it's unsprung..
My 18" TE's with 265's were still light as fuark
Gotta do what you can when you're a monster like yourself ey Dezz? Lol
Look up un-sprung weight..
Dezz, you get my PM?
no. just i reckon i might have them mate with a curb, and i wouldnt want to do that to real TE's
Shit driver, jk! :rofl:
powerfc / new coilovers / clutch / turbos
are the things im looking at right now
but i want everything! lol :P
I figured the previous owner would have done all that...
People can roll on what ever (Genuine / Fake) just don't boast about it if they are fake.
Can I brag about my $1200 D1Rs lol? They are real!
Real/expensive lightweight wheels are what you put on a track car when you're trying to save every gram of weight from it because you've already done all you legally can to get power out of your engine. And 16kg is a LOT of weight to save on a track car, so then it's worth the $4k. I know people who remove useful bolts from their cars in an effort to save weight lol.
You also use real on the track because a lot of fakes or cheap wheels have balance issues at speed. Some, like my Lensos will shake/vibrate the wheel at 100km/h and there's nothing you can do to balance it...it's annoying but manageable on the street, so I'd go fakes every time, but that's me. Others will pay for a guarantee against these issues and it's not like they lose a huge deal of money on sought after pricey wheels.
I'm saying they suck because ones getting repaired because of a pissy little pot hole.
Shoulda paid a little more and got some quality rims.
My very real and rather expensive Advans got lunched by a pothole too...got nothing to do with cheap rims.
nah ash is selling TE's im pretty sure.
yeh because you bought ROTA pieces of shit
Rota/ varrstoens, same shit.
I'm not pissed cause they only cost me a grand but you wouldn't expect them to crack over such a mild pot hole.
Oh well. LMGT1s for the 32
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
