inb4 Dezz bankrupts Govt with his fat return
Bout f**king time I got something back
Knowing my luck, I'll get f**k all back other than the amount I overpaid due to not being able to claim the tax-free threshold on the new job
thanks man.
i wasnt really happy with the finish of a mates rotas, so i went with varrstoen
you drive a 4 door r32, your in the same category as mohsen therefore your point is invalid.
thanks mann
were they matt black? mine and I think Leigh's (never heard complaints :P) were great in matt black
It ain't luck brah, just gotta know what you can claim, if anything. People with minimal deductions often think they are being ripped off etc, just means you haven't had to spend as much to earn your income
Nah a bronze finish. The spray was abit unco on a few of the wheels. But meh mine a here now no point. I'm really happy with em so hopefully I wot fall into the category pf shattering wheels.
I had work Meisters on and I managed to buckle both fronts so I don't think the price u pay for em has anything to do with it
Won't have to do another one for 5 years unless your usage drastically changes :thumbsup:
Also have a soft spot for 335i. Modern day skyline. 3.0L inline 6 twin turbo and from what I hear simple tune, exhaust etc can bring it near 300rwkw
325i coupe - $90k driveaway
335i sedan - $100k driveaway
335i coupe m sport - $130k driveaway
M3 coupe - $170k driveaway
nah it doesn't a broken wheel is a broken wheel no matter what it cost you
335s are dropping because people are anticipating the release of the new F series coupe. Even though that seems quite some time away.
So I'd say it is a good time to buy. Spend a few thousand on this site: http://www.burgertuning.com/ plus labour, you're looking at an easy 300rwkw. (I'm talking the older n54 engine, the n55 still has good gains but not as high being a single).
If anyone wants a ride in a tuned 335i hit me up!
Might take you up on this, I got a friend who is pretty interested in buying one and modifying it. Be good to let him know how they go with a bit of work.
and you and your ATO buddies can smoke me :thumbsup:
What area in the ATO do you work in Ric?
+ 1. I would say if I ever decided to grow up the 335i is on the list of cars to get.
Though us east siders will have to travel to the west lol
I'd get a second hand one not a new one :D
Difference Between me and mohsen is I drive mine
Also your car is bright orange, your opinion of my opinion is this invalid
Just shit stirring anyway I don't care who runs fakes as long as I don't hang out with them haha
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
